Results 1 to 2 of 2
Thread: vp aircon drain tube
    VP Commodore
    Feb 2011
    Wollongong
    Default vp aircon drain tube
    having trouble finding the drain tube on a vp comm. got car on ramps, found a little rubber hose sort of coming down on the drivers side of the trans not sure if this is it or this a breather for the trans. anyone got pics or anything that can help??? Thanks Ben
    1991 vp v6 sedan
    Feb 2011
    huskisson
    Default vp aircon drains
    i just got under and stuck a piece of wipper cord up the holes ,would only go 2 or so inches up then no furher.the right hand side released a lot of water as soon as i touched the split rubber cap on the drain opening,did not seem to be dirt holding the water up the tube,seemed like the rubber split had stuck together.i will see if the water now keeps coming in on the drivers side floor.The left hand side floor does not get wet and when i put my finger into the left hand side drain no water came out so it seems to be draining from there ok,but the rubber cap on the drain felt like it had half broken away.
  1. aircon water only comin from 1 drain hole under car
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2008, 12:47 AM
  2. blocked aircon drain - leaking in the car on drivers side VR
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2006, 05:42 PM
  3. AC Drain Tube Rework
    By hkmonaro68 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-11-2006, 06:22 AM
  4. VL aircon vacuum tube matchup. HELP!!!
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-07-2006, 09:40 PM
  5. VL aircon vacuum tube matchup. HELP!!!
    By dibly1980 in forum General
    Last Post: 23-07-2006, 04:13 PM
