Quote:
Originally Posted by Reaper
First step is to check the tension (most likely) and then that the pulleys are in line. Also check that your aircon compressor isn't seized.
Reaper
how do I check if they are inline, is this just a visual inspection - if so, they appear to be ok. compressor was reconditioned so there should be no problem there.
Quote:
Originally Posted by accentstencil
When you turn the A/C pulley by hand, is it hard to turn or is there excessive play? Does it happen regardless of whether the A/C is turned on or off?
the a/c pulley is easy to turn by hand, and the issue only occurs when the ac is turned on.
