+ Reply to Thread
Results 1 to 3 of 3
Thread: Replaced H/U, antenna not going down?
    VY Lumina
    Jun 2009
    Default Replaced H/U, antenna not going down?
    Hey. In my VY Lumina today I replaced the single disc blaupunkt H/U with a 6 disc one from a VY, not sure which one, but it has FF/FR buttons not Up and Down. All working fine and all, only thing is that the antenna does not go down when I switch to CD or turn it off as it should. I'm 99% sure when it was first turned on, it must have gone back up because it would have gone down when I turned off the single disc. Anyone got any ideas what I did wrong?
    vx berlina
    Apr 2009
    vic
    check ur fuses. if the wires were cut at the back of the headunit it may not of been connected bak up right
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you Phreddy ClubSport Phreddy ClubSport
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    The antenna for the "Premium" system (the type that has antenna up/down buttons) is a different type to the standard one. This antenna actually "remembers" the last position it was in. The output format for the antenna control is different between the two systems - The standard unit simply has a pin which has voltage applied when the antenna is to be driven up, but no voltage to drive the antenna down. The Premium system has a different setup here, giving different outputs depending on whether the drive should be up or down, then the antenna drive unit itself remembers where to set it.
    Now - to fix it 100 %, to'll need to either change the antenna to the standard type, or put the original HU back in.
    (and the latter would be my suggestion actually - another thing that the Prem system is capable of is driving 2 ohm speakers, which the standard unit CAN'T. If your car has had a Prem in the dash, then there's a good chance that the speakers are in fact 2 ohm, and if you connect these to a standard unit it's going to give problems eventually. The standard units are only able to drive 4 ohm speakers, and will overheat if running 2 ohm drivers.)
    Hope that helps.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
+ Reply to Thread
  1. [Buick] What needs to be replaced
    By -ToM- in forum V6 Development And Modification
    Last Post: 10-06-2009, 09:19 AM
  2. replaced stereo
    By nqgrunt in forum Car Audio
    Last Post: 16-02-2007, 06:02 PM
  3. Can it be replaced
    By Just_Ice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2006, 09:04 AM
  4. Can it be replaced???
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 03:50 PM
  5. Replaced the Oxy sensor
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 11:08 AM
