Results 1 to 7 of 7
Thread: Exciting news - jbl car audio product now on-stream!!
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Talking Exciting news - jbl car audio product now on-stream!!
    At long last, I have availability and pricing on the JBL '09 range!!
    Thanks to all who have waited so patiently, by way of making that up I have sorted out some very special bundle deals, with an even bigger reduction for a limited time - PLEASE SCROLL DOWN A BIT for details of the limited offer!
    The prices below are for the more commonly required components among we Commodore pilots, but I also have access to most other products in the JBL car audio range. For further information on the products please see JBL's website - JBL Car & Marine Audio - rather than me duplicating all the specs here, just the basics...
    This is the Just Commodores member based pricing, which requires that you're not only a member of the forum, but a CONTRIBUTING member... (see explanantion in a separate thread soon to be posted in the ASR sub-forum)
    A basic rundown of the most common components below....
    6.5" splits:
    GT5-650C - 50WRMS 4 ohm 160mm (6.5") 2 way component system. "Plus One" mid-woofer, 25mm titanium dome tweeter. JC members $130 (RRP-$159)
    GTO-608C - 70WRMS 2 ohm 160mm (6.5") 2 way component system. "Plus One" mid woofer, 25mm MyTi edge driven dome tweeter. JC members $215 (RRP-$269)
    6.5" coax:
    GT5-652 - 45WRMS 4 ohm 160mm (6.5") 2 way coax. "Plus One" mid-woofer, 25mm tweeter. JC members $88 (RRP-$99)
    GTO-628 - 60WRMS 2 ohm 160mm (6.5") 2 way coax. "Plus One" mid-woofer, 25mm MyTi edge driven dome tweeter. JC members $105 (RRP-$129) NOTE: Not yet in stock - Expected availability mid September.
    Woofers:
    GT5-10 - 275WRMS 4 ohm 10" single coil woofer, 30-500Hz. JC members $110 (RRP-$129)
    GT5-12 - 275WRMS 4 ohm 12" single coil woofer, 27-450Hz JC members $125 (RRP-$149)
    GTO-1014 - 350WRMS 4 ohm 10" single coil woofer, 25-400Hz JC members $149 (RRP-$179)
    GTO-1214 - 350WRMS 4 ohm 12" single coil woofer, 23-400Hz JC members $199 (RRP-$229)
    Amplifiers:
    GT5A-604 - 4 x 60WRMS / 4 ohm . JC members $225 ( RRP-$299)
    GTO-504 - 4 x 55WRMS / 4 ohm, 4 x 70WRMS / 2 ohm. JC members $325 (RRP-$399)
    GTO-5355 - 4 x 55 + 1 x 225WRMS / 4 ohm, 4 x 70 +1 x 360WRMS / 2 ohm. JC members $489 (RRP-$599 - GREAT VALUE!! FULL AMP SOLUTION!)
    I'm offering the following packages at a further 5% off for one month only, orders must be received and paid by 05 September 2009. They include a four (or five) channel amp, 6.5" splits for front, and 6.5" or 6x9" coax units for rear. This is suitable for VT-VZ Commodores, the 6.5" speakers do fit in the factory mounting buckets with slight modification. If 6x9" rear units are chosen (for parcel shelf mounting) then grilles will also be required for installation, among the other usual cable / terminal / hardware supplies. THIS REDUCTION ONLY APPLIES TO THE PACKAGES LISTED - NOT ON INDIVIDUAL COMPONENTS. (I'm keeping the pricing on this gear VERY competitive, so the extra discount only comes with a multiple goods purchase) If you need the goods sent to you, then you'll be copping the freight as well.
    Note however that I can negotiate better prices if you'd like me to perform the installation work.
    Good 4 channel package
    For 6.5" rears (door mounted):
    Front speakers GT5-650C RRP-$159 ASR Price-$130
    Rear speakers GT5-652 RRP-$99 ASR Price-$88
    Amplifier GT5-A604 RRP-$299 ASR Price-$225
    Total RRP- $557 ASR Price-$443 SAVE $114
    1 month only ASR Price $420 SAVE $137 on RRP!!
    For 6x9" rears (parcel shelf mounted):
    Rear speakers GT5-963 RRP-$149 ASR Price-$120
    Total RRP-$607 ASR Price-$475 SAVE $132
    1 month only $451 SAVE $156 on RRP!!
    Better 4 channel package
    Front speakers GTO-608C RRP-$269 ASR Price-$215
    Amplifier GTO-504 RRP-$399 ASR Price-$325
    Total RRP-$767 ASR Price-$628 SAVE $139
    1 month only $597 SAVE $170 on RRP!!
    Rear speakers GTO-938 RRP-$199 ASR Price-$165
    Total RRP-$867 ASR Price-$705 Save $162
    1 month only $670 SAVE $197 on RRP!!
    Best 4 channel + subwoofer package.
    Custom fabricated 2 x 10" or 2 x 12" enclosure - boot mounted, convenient brackets and "tri-wing" bolts for retention, high current "Speakon" connector for rapid and safe disonnection. Full access to spare and jack without enclosure removal, but can be removed in less than a minute if necessary. It's a fully sealed type enclosure, aimed more at SQ than SPL. Carpet covered in either charcoal or "ASR blue", protective metal grilles, pocket handles fitted, fully leak tested. The 2-12 enclosure has an internal volume of 2 cubic feet, the 2-10 a volume of 1.6 - this matches not only the JBL woofers, but most other 10" or 12" mainstream units. Also in this package is ASR's very own amp mounting shelf - 4mm solid aluminium "propeller plate" (like checkerplate, but much shinier), drilled and tapped for amplifier and bracket mounting. Includes piano hinge for upper crossmember mounting, and screws / brackets for rear edge retention. Fully buffed top surface, mirror shine. (reflects all cables and connections, looks very pretty!)
    Just as a side note, 6x9" parcel shelf speakers are not recommended in an installation such as this, as the subwoofers will "pump" the cones of the 6x9" units affecting the sound quality...
    Woofers GT5-12 x 2 RRP-$149ea ASR Price-$125ea
    OR GTO-1214 x 2 RRP-$229ea ASR Price-$199ea
    Amplifier GTO-5355 RRP-$599 ASR Price-$489 SENSATIONAL!!!
    Custom enclosure - RRP- N/A ASR Price-$275
    Custom amp mounting shelf - RRP- N/A ASR Price-$100
    Total (GT5-12 woofers) RRP-$1640 ASR Price-$1417 SAVE $223
    1 month only $1346 SAVE $294 on RRP!!
    (GTO-1214 woofers) RRP-$1800 ASR Price-$1565 SAVE $235
    1 month only $1487 SAVE $313 on RRP!! DAMN!!
    PLEASE NOTE that the above prices DO NOT include installation or supplies - such as cabling (for power, RCA interconnects, and speakers), fuses, mountings (apart from the "Best" system with the amp mounting shelf included). Basically, expect to spend at least another $200 plus on such supplies, depending on the quality level you're after. Naturally, should you ask for me to source these materials I can help you out there.
    Also it doesn't iclude the line out modification to the head unit, which may or may not be required. (ie - if you have an aftermarket head unit, or have previously had the ASR line out modification done, then that's that... Otherwise that's an additional cost, pricing really depends on the "other" work that will be done.)
    I can also get quite good pricing on Stinger accessories and Dynamat damping material, or for the more budget conscious I can get most of what you can find in the Jaycar catalogue for a little better than retail pricing. Naturally installation services are available in the Sydney area, or perhaps on a "Roadshow" tour if you're from elsewhere. Don't forget, these aren't the "top shelf" JBL compoe\nents either. Should you require something a little more, I can also do Power and GTi series. (requires a bit fatter wallet though...)
    For anyone wishing to order - PLEASE READ THIS CAREFULLY!!
    DON'T send me a PM to place an order - PLEASE DO send me an email - phreddy@asr-audio.com.au - if you send me a PM it might introduce delays, as I'll simply reply asking you to send me an email...
    So be quick - the introductory specials WILL CEASE on 05 September, no exceptions. After that the still competitive prices will apply.
    Cheerz!
    Last edited by Phreddy; 06-08-2009 at 10:47 AM. Reason: formatting buggered up - looked like bollocks...
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Yes
    Greg, ill have a chat to you about a package when i get back from overseas.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Richie - definitely! -
    Paul - lookin' forward to it!
    Seriously, I am working on plenty of text content for you Rich - although this thread's not the place to talk about it.... Will be in touch real soon.
    Cheerz!
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    VZ SV6 && 180sx
    Mar 2008
    Awesome!! Will absolutely be making an order in the future..
    Are we able to see some pic's of the sub enclosure, or boot setups?
    Torquative's Avatar
    Torquative is online now go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    if i wasnt needed to spend 3 grand just on mechanical and other bits to bring the Acclaim back to scratch for the rego I know where i'd be pouring it.
LinkBacks (?)
  1. 09-12-2010, 10:47 PM
  1. sound stream??
    By SAV_117 in forum Car Audio
    Last Post: 17-09-2008, 09:07 PM
  2. My exciting time... Stupid VN.
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 02:00 PM
  3. FS: Sound Stream LIL WONDER II LWI.350 AMP
    By V-ahhh in forum Parts And Other Items For Sale
    Last Post: 31-10-2006, 10:12 PM
