Results 1 to 6 of 6
Thread: VT stock HU sub and amp
    VT Berlina S1
    Aug 2009
    Question VT stock HU sub and amp
    Just wondering if it's possible to connect up a sub and amp using the stock HU in my VT?
    If so does anyone have a wiring diagram and also who knows of some good audio shops that could do it if I need to?
    VX Commodore Acclaim S1
    Nov 2008
    Goulburn NSW
    Please read before posting new threads
    Phreddy can do it, there is a post in here that explains that he has made LLRCA (low level RCA) outputs, exactly what you need. (where it is im not sure)
    but thats what you want.
    Quote Originally Posted by Jecs View Post
    its a nice day for a jog. so jog the f**k on.
    VX acclaim S2
    Oct 2009
    if its the same setup as the VX then im sure i could help u. about a week ago i was in the same position mate. wanted to keep my stock head unit, but wanted a sub and amp. you need a line out converter from your local autobarn or somethin. then tap into your speaker wires with that.run ur rca cords fromt he converter down hte right side of the car under carpet trim, then ur opwer cord from ur positive terminal through the firewall and under the carpet trim on the left side of your car. hook up your remote wire to the accessories cable from behind the head unit which is yellow from memory and run that down with your RCA's. then put them under your seat and into the trunk and attach all to your amp.. find a ground bolt or something for negative and then some speaker wire from the sub to amp. I hooked up a 600Watt sub to a 2 channel 600Watt amp and i just bridged it and tuned a little. took me bout 3 - 4 hours for everything. but worth it mate!!!! sounds real good! message me if u need help with anything specific
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
    Kizza50... you realise this is a SPONSOR forum right? Id think Phreddy isnt going to be to impressed with you giving ideas out to someone elses product? Just a thought...
    Nov 2008
    Goulburn NSW
    Quote Originally Posted by kizza50 View Post
    if you want it done so it sounds shitty, please follow this procedure, if you want a proper, professional job, Email phreddy.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Exactly Jak - getting well and truly over this.....
    Yes I can help. I can help PROPERLY. If you want it to actually sound GOOD that is.... If you just want to hang with the MaccaNats crowd making nasty noises, then the LOC would probably do the job.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. t78-33D on stock 5.0L
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 19-02-2009, 11:05 PM
  2. Cam for stock VP SS???
    By bigred304 in forum V8 Development and Modification
    Last Post: 06-10-2008, 10:50 PM
  3. Stock vh 1/4
    By VH commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2008, 03:33 PM
  4. how come stock 1.8 auto lancer beat stock vl
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2005, 08:47 AM
  5. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
