Results 1 to 8 of 8
Thread: VZ Headunit with sub and amp
    VZ SV6
    Jul 2009
    Default VZ Headunit with sub and amp
    Hey people
    Im currently looking to install a sub and amp into my VZ but keep in mind that I want to keep my stock headunit
    Is this possible,
    Ive heard of RCA line level converter but I dont have a great understanding on them and where can they be purchased?
    Any help much appreciated
    -scyth-'s Avatar
    -scyth- is offline Im alright its the others
    VZ Wagon 05
    Nov 2008
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Thanks Zeussy and Scyth - Ash, I have received your email. I'll reply shortly with my phone number, as I reckon it's probably better to actually "chat" about it.
    Cheerz!
    PS - Never never NEVER use LOCs... (Line Out Converters) THEY SUCK GOLF BALLS THROUGH GARDEN HOSES!! Causes you to effectively waste your money on the high quality components you're using externally - doesn't matter how good your amp and speakers are, if you're feeding them a crappy signal, they'll sound - well, crappy! (by comparison to how they COULD be performing, anyway...)
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    VN berlina
    Dec 2009
    Default installing amps and subs to vz
    Edited to replace the CRAP that ASR has CONTINUALLY requested BE KEPT OUT OF THIS SPONSOR'S FORUM.
    Learn to read before you try to participate in an activity that requires - well, READING!
    Damn....
    Zeussy's Avatar
    Dec 2008
    Central Coast
    VY S
    Dec 2009
    Default advise
    Depending on the sort of sound quality you want
    With a standard line level converter it takes the speaker output of the factory head unit and turns it into a rca output, the only problem with this is sound quality and sometimes a chance of engine noise. The poor sound quality is because of two reasons, one the factory head unit doesn’t have anywhere near the same power has an aftermarket head unit and two it doesn’t have the EQ for it. A line level converter can cost anywhere between $30 to $150 depending on the quality and functions. If you are worried about sound quality I would suggest to go for a processor which is basically a pre amp which has the power and massive EQ it makes any factory head unit sound amazing but it does cost around $1400
    hope this helps
    Ni(k
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Even with a sound processor, it will still be effectively driven by an LOC. And a LOC does NOT really tuen a speaker level output into an "RCA" output... It simply limists the signal voltage, to make it appear to be RCA signal levels. A TRUE RCA output is driven out of the PRE amp, before the internal power amp stages. Those processor units CAN be made to work very well, but LOCs are a dirty word on the ASR forums....
    My business is based partly around modifying factory units to provide true pre-amp outputs. It can be done, and the results are astounding. Before anyone spouts how it can't be done, should maybe spend a little while longer reading around these - and other - forums. The technique was developed - by ASR - several years ago, and in countless installations performs to show-winning standards in some cases.
    But I will ask again - for the umpteenth time - please do not be advising people to buy aftermarket head units in the ASR forum! There's a general car audio forum on JC for that, thanks.
    Oh, and power levels from a head unit are all much the same - regardless of how the manufacturers fiddle their figures.... The best you will get into a 4 ohm load, from a 13.5 volt power supply, is about 17 watts RMS. (note I refer to RMS power...) Into 2 ohms, obviously you'll practically double that - but not many HUs are capable of two ohm loads anyway. It's a physical truth - a fact based on true principles of electronics. To say that aftermarket HUs are more powerful than the factory unit isn't really correct...
  1. Headunit help
    By apoc585 in forum Car Audio
    Last Post: 26-10-2008, 08:33 PM
  2. VY Headunit
    By sickhg in forum Car Audio
    Last Post: 22-10-2007, 06:31 PM
  3. help please with headunit
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 09:41 PM
  4. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  5. headunit in VK
    By Shifty1 in forum Car Audio
    Last Post: 01-07-2005, 03:36 PM
