Okay so i have the vy ss six stacker with blaupunkt unit, which has the phreddy options, im wondering if i was to put this headunit in another vy that hasn't been modified will it all fit? i only need to do this to recode the headunit.
cheers for answers rep for answers![]()
Vy ss sandman, bringing back the past![CENTER]
why would i have to swap the cage,
by looking at what phreddy did, its literally just like putting in a new cd player. . . . and depending on where your aux in and low outputs are placed you move those as well. (hope that made sense)
Hit the star under this post if it was any help to you =D
um i think i get you but i dont think my question made sense. when the cd players are modified, there is a little black thing which all the plugs go into . this is glued just above the old plug. my question is. if i was to try put my modded cd player in a car with the cage that isn't modded with the little black thing hit?
cheers sorry about the long question
yes ur unit will work inside another car as a standard unit it'll need the code 4 it tho which im guessing is wat ur tryna retrieve?
yessirthanks once again mate
im heading down south soon so i decided ill just take the unit and put it in another car down there and do it![]()
I thought that phreddy glued the connecting plug into the cage, but its been a while since he did mine so i might have been confused with him cutting the cage and not fitting the plug to it.
either way you will have to pull out the cage fom the new car and cut it so you might as well just change them over
haha im only reprogramming my unit taking it out and putting back in my car.
