i pulled the head unit out in my vy executive to have a look at the wiring for putting an amp in. when put back in nothing works on it but has power to it. all i can see is the time.
any ideas to help?
thanks
make sure all the plugs are properly plugged in.
and aslo check if the antenna is plugged in.
I have had many cars come in were the antenna is not plugged in and the deck wont work.
so how would i go about that. so the antenna would be the round one in the corner right? and how could i get to that without removing the unit again? just had a quick fiddle but didnt really get naywhere?
Take the deck out to do it properly mate becasue you got to check all the connectors if there are plugged in properly.
factory
will try that
well now im confused.
i realised that i cut wires from the old nokia hands free kit and started to wire them back up. i have the stereo working but only the volume on the head unit and steering wheel controls work. sorry i missed that info b4 about the nokia thing. should i just re wire all the wires from the nokia kit?
