G'day Y'all
Can't find where the console part no's are
want to finish off the aux mod with the custom console parts
Can any one help out?
VZ-Rob
98 Ron Powerchip: CAI: SuperLows: GTS Swaybars: Tinted: SS Grille: SS Vents: SS 2:25 Twin Exhaust: ASR Audio:
Cover Accessory switch:
Black- 92111637
Tempest Grey- 92111636
Bezel Accessory switch:
Black- 92111641
Tempest Grey- 92111640
Thanks ! all installed looks great
However the aux socket now only plays 1 channel
how do you get the blank Accy cover out again?
so i can check if the wiring is broken ?
VZ-Rob
Ahhhh!
Thanks Ant, for giving those numbers to Rob. (I need to reply to your email too - been FLAT OUT Mate, will be back to you real soon....)
Now - Rob - was I supposed to get those for you Mate??? I can't remember.... (finishing the job at 2:30am - or whenever it was - I was a bit foggy.... heh...)
By the way - haven't forgotten about your dome light - in progress at the moment. Sorry about that, but I had to put the energy into this training - great opportunity, couldn't let it go...
Now - about the AUX now only working on one channel....It was working OK at first, right?? (I'm sure I wasn't too tired to actually test it properly...) I guess it's possible that one of the solder joints to the socket has gone flaky...
Anyhow - trouble is, in order to get that bezel out, and then the dummy cap, you need to snap out the lower centre panel from the console. Start by removing the single screw from up underneath the radio (beneath where the ashtray would be, biased slightly to the right - you need to get down low to see it), and then lift up the grey bit after opening the console bin lid. The clips will snap out from the back, just work your way forward from there and you'll be able to get to it. You might have to unplug the window switches as there's not much slack in the harness....
Sorry about the troubles Mate - let me know if it runs any deeper than that.
Cheerz!
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
Thanks for that. i suspected I'd need to take the console out.
Naw! Aux worked great did a run to Adelaide and back to Melbourne and had the phone plugged in Aux sound and CD sound is great!
Lots of positive comments from people on the dash light mod (even the missus)
Having the separate amps for the tweeters and woofers for tuning works a treat
I'm sure a solder has cracked will fix on the w/e
VZ-Rob
Note to Phreddy:-![]()
Put a dob of hot glue between the terminals once soldered to prevent shorting out.
What happened ? The terminals folded over onto each other when pushing up into the
blank plate and was shorting out.
All good now. Individually shielded with tape and problem fixed .
VZ-Rob
