Results 1 to 7 of 7
Thread: changing cluster from vz to vy
    vy
    Aug 2010
    finley nsw
    Default changing cluster from vz to vy
    hey all i was just wondering if it is possible to fit a cluster out of a vz in to a vy ?? wat thing do i have to look at ?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Dont think it works that well - fuel gauge goes the wrong way from memory...
    and 3 Dangerous non ABS VN's
    VYII LX8
    Jun 2008
    ^^^^ As above
    You'll have to check that you have the correct coloured plug in the back of the cluster (blue or grey). From memory only series 1 VY suits VYI, series 2 -> VYII and so on. Also the fuel sender may need replacing to get the fuel gauge to work the correct way which is around the $400 mark.
    alshemary's Avatar
    alshemary is offline drive it like u stole it!
    300ZX Twin Turbo/VZ SS/VY Calais
    Apr 2010
    Perth SoR / Bentley
    i wanna change clusters too but am not sure how to do so or where to start.. i am affraid of screwing with warning lights / odometer readings
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    simple answer is stick to VY dash for VY and VZ dash for VZ. (blue plug is VZ grey is VY) as the fuel guage reads wrong if you miss match.
    If you get a dash from a V8 to fit to a V6 you need it re-calibrated to suit, as the speedo will be out for instance.
    VY s m5 supercharged
    Aug 2008
    this should be moved to another section but for the VY series 1 you cant use a series 2 as the fule gauge works in reverse, after the series 1 you just need to get the same coulor plug to sute yours.
    if its out of a different speck car to yours you will need to get some things changed like motor type, trans, number of air bags, etc, the motor wont throw out the speedo the diff steeings will, the motor will give you strange rpm readings.
    was: VZ SV6 M6 2004 is: VX SS M6 2001
    Mar 2009
    Its all been covered pretty well, its basically an entire splice job if you dont line everything up, easiest way could be when you get the new dash, get the harness plugs with it, might be able to change the ends to suit... but this also depends on transmission/engine/dash trim level (features).
  1. Changing the ODO clock on my lvl 2 Cluster
    By Jordzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2010, 11:13 AM
  2. legality of changing odo cluster....
    By TheForgotten in forum General
    Last Post: 21-07-2009, 07:41 PM
  3. changing the v6 cluster to a v8 one
    By NEDWOB in forum General Discussion
    Last Post: 16-05-2009, 09:34 PM
  4. changing cluster
    By Phoenix21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 10:20 PM
  5. Instrument cluster globe changing....
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 11:39 PM
