Results 1 to 3 of 3
Thread: VE Blaupunkt options
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default VE Blaupunkt options
    I'm considering purchasing a VE Omega early next year, and i would like to discuss what options are available for retaining the factory integrated units.
    I'm aware of the basic LOC options, and i have also been looking into the available range of signal processors, neither of which appeal to me. I can't get my head around the whole idea of processing a signal that i am unhappy with....
    To my knowledge , the output signal produced from any source comes down a lot to the quality of the DAC, and the transport itself should have little overall bearing.
    So i would like to know what can be done to the factory integrated units to improve signal.
    1- Can you change out the DAC to a better quality item?
    2- Otherwise is there any way to add a digital output to the CD transport and bypass the factory DAC, allowing use of one of the factory sources as a pre-amp to something of better quality.
    If what i am after simply cannot be done then i will accept that, and i will have to look at completely replacing and modifying the centre unit to accept some other form of multi media station. If someone from ASR would be interested in attempting the above please let me know.
    fsa
    Jan 2011
    usa
    I need like a wiring diagram to help me out , i wired it manually , cut plug off and done it all meself , normally a wizz at things like this but things didnt go to plan this time round. any help would be much appreciated.
    Feb 2011
    usa
  1. rev limit??
    By arex7 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2009, 07:43 PM
  2. 253 rev limit
    By Nobody Actually in forum V8 Development and Modification
    Last Post: 09-11-2008, 01:49 PM
  3. Age limit for pub
    By one_and_only2004 in forum The Pub
    Last Post: 26-03-2008, 10:08 AM
  4. What is the VZ SS rev limit?
    By onefifty in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-11-2006, 08:24 PM
  5. limit??
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 10:34 PM
