Results 1 to 5 of 5
Thread: VP lvl 2 Dash upgrade to lvl 3 dash
    vp v6 s pack
    Dec 2010
    Bowen
    Default VP lvl 2 Dash upgrade to lvl 3 dash
    Hi, I currently have a level 2 dash in my 1992 VP commodore, however I want to know if I can upgrade to a level 3 dash from either a VR/VS or a VQ statesman. I also would like to know if it's possible to get the bottom three digital displays working. Also some sort of wiring diagram would be nice too
    Thanks
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    From everything I've read, you need the BMC as well...
    I wouldn't normally comment on this stuff, but fugg it had a couple drinks and no other bastards on here tonight.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You can run a level 3 cluster in a VP - just need to get a converted switch block to keep the interior light delay and rear demister working. You use the VN patch loom with the extra plug on it to run the modified switch block. I've made 10 VP kits so far and as far as I know all have worked.
    You dont need to change the BCM. You need a patch loom, modified switch block and cluster
    and 3 Dangerous non ABS VN's
    Feb 2011
    usa
    I also would like to know if it's possible to get the bottom three digital displays working. Also some sort of wiring diagram would be nice too.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Joesf.Gil View Post
    Read the tripin thread. Great info in that. The patch loom will get the trip computer working. + a modified switch block to keep the 3 modes in order along with the interior light delay and rear demister. PM me if you want some help to do the conversion.
  1. vs dash upgrade
    By jenny-3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2012, 07:12 PM
  2. Upgrade VN Dash Pad to VR or VS Dash
    By shaneh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2011, 11:36 AM
  3. VR Dash Upgrade....
    By charvel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2010, 12:37 PM
  4. Dash upgrade
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 09:56 PM
  5. VP dash upgrade??
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2006, 08:08 PM
