Just wondering if putting a neon light bulb in my boot would work, if so, how do you put it in?
I tried removing the case as it is in the interior light, but it wouldn't budge.
Should I clench my balls and be a bit rougher or is there a trick to it?
I drive a VT commodore, cheers
get a really small thin flat blade screwdriver and prise it open from the inside of the boot part of the light casing... does take a smidge of force but not too much
You change it by asking in the VT section.
-My VZ Acclaim- feat. ASR Audio Sound/Lighting and Various Other Mods
