Results 1 to 4 of 4
Thread: headlight switch not lighting up
    BAW
    BAW is offline
    VZ exec
    May 2009
    Default headlight switch not lighting up
    my headlight switch always used to be dim (vz), so after hearing about the led dash conversions, i took it apart and had a look.
    one of the bulbs had blown, and in the process of "looking" at it, i snapped one of the other bulbs off.
    after that it never lit up at all.
    so now i have bought another one off ebay, sold as 'working' but this one doesnt light up either.
    i'm waitng for phreddys adelaide road trip to get a conversion done, but is there something i should do to avoid the led conversion not working either?
    am i just unlucky and the ebay one is blown aswell? or is there a deeper problem somewhere in the wiring?
    anyone heard of this before?
    anyone had a blown switch and a led conversion fixed it fine?
    thanks
    please move thread if necessary
    edit: just checked, all bulbs blown on the new switch wonder if its bad luck, or something is causing the bulbs to blow.
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Most of the VY/VZ by now will have blown at least a couple bulbs in the headlight switch, sometimes the trip computer switch and almost always the rear power window switches. When i converted my VY recently (135,000km on the clock) 2 out of the 4 globes in the headlight switch were gone, and desoldering them was enough to finish off the ones that were still going .
    Just replace them with LEDs. You need a 680 or 750ohm resistor in series with each LED. Sand the tops of 3mm LEDs to get decent light dispersion.
    Keep in mind when testing that the headlight switch is powered by the key in the ignition being turned to ACC, not the headlight switch being set to on, common error
    BAW
    BAW is offline
    VZ exec
    May 2009
    thanks for the replies.
    all bulbs so far have been standard factory bulbs
    i hope that the bulbs have just all died naturally, and a LED conversion will fix it.
    if it doesnt.... then i'll have to do some more "looking" around
  1. light switch lighting up
    By VL Berlina 5speed in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-06-2011, 06:41 PM
  2. 92 VP Right hand side Switch Block with headlight switch and DIMMER switch ONLY
    By melmoran86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2011, 04:13 PM
  3. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  4. Headlight switch
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2006, 05:52 PM
  5. Headlight selector knob not lighting up!
    By VL Soldier in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 08:55 PM
