Results 1 to 2 of 2
Thread: Vt Berlina electric window issue
    Vt Berlina
    Feb 2012
    Default Vt Berlina electric window issue
    does anyone know what would cause the orange/yellow wire found on the plug leading to the electric window switches (console) would be blackened inside the plug housing? the connecter appears to be burnt out but before i repair it i was hoping to find out what would be the cause...or is it just from long term use?
    cheers scotty
    VH SL/E 381pack
    Jan 2011
    BROOKDALE W.A
    Smell it to c if it smells burnt. It could b dirt or grease from previous owner.
    If it's burnt u may have a bad earth.
    Or it could b the window switch block. It can get hot and melt the ends of the little plastic pins inside it. Wen they melt to much, the window won't go up or down or both cause the pin presses a little copper/brass seesaw bit of metal down too the switch that controls the up or the down function. If it melts too much it can engage the up and down switch at same time constantly which will make the wiring harness hot and can start burning at certain places.
    Hope u understood that. I think I confused myself reading it lol
    Mick
  1. VT Berlina electric window issues
    By scottyc13 in forum Electrical Wiring / Questions
    Last Post: 05-02-2012, 10:25 PM
  2. [NSW] WTB: VX Berlina Electric Window Center Control Bank
    By Andy in forum Swap / Wanted to Buy / Trade
    Last Post: 29-01-2012, 10:36 AM
  3. VT Electric Window Conversion - Drivers Window Down
    By cjcrow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2011, 02:44 PM
  4. VT Electric Window issue.
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2010, 11:24 PM
  5. VT electric window swithch issue
    By ucome2 in forum Electrical Wiring / Questions
    Last Post: 11-05-2006, 10:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
