Here we are folks, the long-awaited FAQs for the VY/VZ Blaupunkt stereo mods. As more questions come to light, I'll be sure to keep this list up to date.
Q: What models can your mods/kits fit to?
A: At the moment, only VY and VZ Commodore / Monaro are covered in the ASR kits. However the circuits could be used in virtually any make and model, it's just a matter of having a suitable unit to locate the signal connection points. In fact, the mods for other manufactures could in fact be less costly - the mod for the Commodore systems includes a specially designed connector mounted to the cradle, as there's no space behind the unit to access the necessary additional connections. In other makes / models where sufficient space does exist the extra cost and complexity of the external connections can be forgone.
Q: What does the mod do?
A: The factory fitted sound systems are nicely integrated in recent times, not only in Commodores, but in many other makes also. The integration of steering wheel controls and HUD information is not only convenient, but enhances safety in not having to look away from the road. Many people don't want to lose these features, plus the units are also designed to blend in nicely with the overall interior look. Those who desire higher performance from the entertainment system are sometimes left a little disappointed with the connectivity options (or lack of them) with the standard unit, so usually the only option is to fit aftermarket - removing the integrated functions (unless you spend a good amount more), and increasing the temptation for thieves. The modifications allow this enhanced connectivity to provide both 4 channel true low-level RCA outputs on one hand, and an Auxiliary Input feature to allow connection of a MP3 player, cassette walkman, laptop audio - whatever has a headphone socket - on the other. These mods can be done one or the other, or a combination of both.
Q: Why go to this trouble? Why not use a Line Output Converter (LOC, or "hi-to-low converter")?
A: This one's easy! The fact is that the very vast majority of distortion in audio systems comes from the power amplifier. (pretty much the last link in the signal chain before the loudspeaker) The power amps in a car stereo are IC devices (Integrated Circuits or "chips") so as to save space and make assembly easy, but they are limited though in the output voltage (hence power) they can produce, and their distortion figures usually aren't very good. A line output converter simply wires in to the speaker outputs and attenuates (makes smaller - the opposite of amplification) the high level signal voltage back to an acceptably low voltage to feed the external amplifier inputs - complete with the distortion introduced by the on-board power amp chips. Regardless of what quality external components you're using, you're feeding them a distorted signal to start with! The output mod picks up the signals internally after the pre-amps, but before the power amp - clean as a whistle. The signals pass through a "buffer" circuit so that external loading or short circuit which might occur won't cause any faults in the unit or otherwise affect the operation. (which can happen - we don't mean to, but sometimes....) For convenience, the mod also provides a remote trigger for the amp(s), also protected from fault conditions.
Q: What about an FM transmitter/modulator for the Aux Input feed?
A: Hmmmm, what about them indeed.... They work OK, but just OK. They're very much affected by interference from local FM radio transmissions (try using one within a few kays of a broadcast transmitter...), and well above that they are limited by the FM transmission standards, which your receiver is designed around. Even a "modulator" type device (which runs in-line with the antenna cable, so it's less prone to interference) suffers from these limitations. Dynamic range and frequency response are limited in FM radio transmission - high frequency rolloff occurs above 13KHz (in the transmitter end to limit sideband production, and de-amphasis of high frequency noise products at the receiver), and dynamic range is limited to about 45dB to overcome the "noise floor". A well compressed MP3 (say around 256kbps) has a frequency range approaching 15-16KHz, and a dynamic range of typically 80dB or more from a high quality player. The only way to achieve a true uncoloured feed from your portable player is hard-wired, simple as that. All of my customers who have changed over from the transmitter feed to my hard wired mod are stunned with the improvement in sound quality.
Q: Is the operation of the internal amps affected? Can I hook up the original speaker connections when I sell the car? (or, fit the mod and keep the speaker connections for now, adding the amp later?)
A: Absolutely yes. The overall operation of the unit is not affected in any way at all. There is no indication that anything is other than factory stock, operationally and aesthetically.
Q: What about the warranty?
A: Because the sound system sub-assembly is dismantled and modified, unfortunately the warranty on this item will be void. However, if you're engine falls out or something, and the dealer blames your modified head unit (if they even notice!), then I think you'll have a good case with the Fair Trading Dept.![]()
Q: I heard that there was a small issue when using the Aux Input with a hands-free kit connected to the unit. Has this been resolved?
A: Yes it has, the final prototype was commissioned to overcome this problem. No aspect of the normal operation is affected.
Q: I'd like to have a go at installing this mod - I did a little soldering at school and built a crystal radio when I was a kid. Can I do this?
A: I would very strongly suggest that without the right level of experience and access to the right tools, you should NOT take this job on. You will need access to the right tools, and you'll need to know how to use them. For those who work in the electronics industry and are comfortable with soldering , then it's quite straightforward. For another who "built a Dick Smith kit years ago, but I couldn't get it to work...", I'd suggest you get friendly with a good technician.
Q: OK, you got me - I don't feel comfortable to do it myself, so I'd like you to perform the mod. What are my options?
A: If you're in the Sydney area, that's easy - I'm located in the Western suburbs. Alternatively, I can do the work on a "mail-in / mail-back" basis - the work can be done overnight and the unit on the way back the following day. The last option is to keep an eye out for the "ASR Roadshow" - I'm planning a trip to each state capital (in Aust) to perform full mods for folks if enough interest is shown. The first Roadshow trips are planned for early 2007.
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
hi phreddy i have just joined this forum and have noticed that your knowledge and skills in the audio department is very good im writing to you in regards to the the current ve stereo, i have managed to install a roof dvd player to it and managed to get the picture things sorted out through the aux function of the head unit but am having problems with the sound input side of things. i live in brisbane and dont have a local tech that i trust so i usually do everything myself but if you know anyone up here im happy to pay for there knowledge / services. or do you have a kit or something? i can buy. any advice would be great thanx heaps.
