Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Sponsors > ASR Audio & Electronics
ASR Audio & Electronics Commodore Factory Audio & Interior lighting specialist http://www.asr-audio.com.au/
Reply
LinkBack Thread Tools Display Modes
  #1
Old 24-09-2008, 06:59 PM
Torquative's Avatar
Sir Awesomness Silverness
Ride: VZ Acclaim and SX6 Adventra
Torquative has disabled reputation
Default Digital Amp
Gday Greg
On the weekend I stupidly brought a Response Class D Digital 5 channel amp. Ive hooked it up and found some issues, I thought maybe I'd ask you for help
- when I connected the RCAs to the REAR output of the radio it got a hum, even using different RCAs. But I can live with that
- the major problem is static on FM stations. Stations like 96.1 and 104.9 get quite bad static, and 91.3 (which I enjoy listening too) is pure static, but when I plug in the old amp they come good.
Im starting to think digital amp was a stupid idea, but I thought I'd ask if you can help in any way I dont know what your knowledge is on the Class D stuff (mine was none til this week) but I know yoru running a good Response setup in the SV6.
__________________
[JCCC NSW]
"Commodore Drivers Are Born ... Not Made"
"Theres one car that says Holden more then any other ... Commodore.
And if it rolls of the production line with a Holden badge on it, you can be assured it goes like a Holden should!"
Holden Commodore Go better
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 24-09-2008, 07:14 PM
garfa's Avatar
Ride: VY SS
Trade Rating: (0)
garfa Calais
hey,
Well what else have you changed? is the power wire the same? is the ground wire the same? is the grounding point the same?
Worst comes to worst you take it back, and demand a refund as your intitled to as a consumer regardless as the item is not "merchandisable"
  #3
Old 24-09-2008, 07:42 PM
Phreddy's Avatar
1st VZ with a blue dash!
Ride: '05 SV6 M6
Trade Rating: (0)
Phreddy MonaroPhreddy Monaro
G'day guys.
Hmmm, I wonder if you might be looking at a slightly flaky ground. I'm not all that familiar with the digital amps, but one thing I would imagine is that they would require a particularly good ground. Even more critical than that for a more "conventional" amp. If this is causing some kind of interference radiation it might be overloading the front end of the receiver. What gauge is your power and ground cables? If it's 8G, I'd suggest that's probably too light for the 5 channel jobby. Need at least 4G. Oh, it's probably worthwhile checking the antenna ground point too - if the antenna cable isn't properly shielded it can cause problems. You are aware that there's a join in the antenna cable, right? Behind the glovebox, there's a line plug/socket combo to extend the antenna cable to the head unit. Make sure that's fully plugged in.
Re the hum problem when the rear channels are plugged - again I'm not sure, but it's possible that the 5 channel digital unit has a different input grounding arrangement, and when you connect both front AND rear, we're forming a ground loop through the shield of the two sets of RCA cables. It might be necessary to use an isolation transformer on one pair of channels.
As Garth pointed out though, if you can't get it to work in your install, then you should be able to return it - or at least exchange it as potentially faulty. Dig your heels in, they should look after you.
Gotta go guys, later!
__________________
New look ASR Website online now!!
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
Click the scales if you like - or not - what I have to say...
  #4
Old 25-09-2008, 06:21 AM
Torquative's Avatar
greg, I wasnt aware of the join behind the glovebox and its possible Ive knocked it as the glovebox was out and I was playing in that general area.
im thinking of upgrading the power cables and connecting an isolator while im at it.
thanks for the tips
__________________
[JCCC NSW]
  #5
Old 30-09-2008, 12:39 PM
Speed is not every think
Ride: Vp Executive Wagon
MattaByte Executive
i have dual digatl amps running my sub and you can't beat them. things you need to check are and the ground cable is at least 4ga and grounded very well. being a 5 channel you need a 4ga power. use mid to high quainty rca cables. spend atleast 40 per cable. and last thing is make sure you have the rca's and power seperate. also if you run a earth along side the rca's it helps with the hum.
  #6
Old 30-09-2008, 08:18 PM
Torquative's Avatar
thanks dude, Im on holidays next week so im gonna strip it right down and go again
The current RCAs have a small earth running along the cable, perhaps I'd be better off grounding one of the old power cables at either end and running the RCAs along side it, or wont that work ie in this case is bigger better or it wont work?
Do you have any suggestions for decent quality RCA's?
__________________
[JCCC NSW]
  #7
Old 02-10-2008, 06:02 AM
Haydz's Avatar
GREENFOAM.. YOU ROCK.
Ride: 94 VR Berlina - 5 Speed
Trade Rating: (0)
Haydz Berlina
here you go matt.
Ryda Car Audio - Stinger SHR17 Hyper Series RCA Lead 5.2 Mtr
__________________
Haydz VR
  #8
Old 05-10-2008, 11:07 PM
Torquative's Avatar
just an update, I took it back for a 2nd time today and managed to sweet talk my way into having it looked at under warranty.
hey Greg, what Response amps do you run in the SV6?
__________________
[JCCC NSW]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Digital TV Issues. fabz The Pub 19 22-03-2007 05:37 PM
Digital Speedo sobvngrpa VN - VP Holden Commodore (1988 - 1993) 14 16-07-2006 10:44 PM
Does VP have Digital ODO? AlpineRaven VN - VP Holden Commodore (1988 - 1993) 2 25-01-2005 06:23 AM
Vk digital Sandri VB - VK Holden Commodore (1978 - 1985) 5 07-05-2004 01:39 PM
Digital Speedo Amcis Electrical Wiring / Questions 4 24-02-2004 08:11 AM
Houses for Sale | Online Image Resizer | Credit Report | Loans | Cheap mobile phones | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
