Hi All,
I was just wondering about ohms, I was looking at Orion HCCA subs, they have a 2ohm version and a 4ohm version (same price), I was just wondering which would be better? and also what the difference would be. At a lower impendance you get more power (from amps anyway) at the downfall of it running hotter ye?
But in respective to SPL, is there a difference? the Orion subs are rated the same RMS for the 2ohm and 4ohm.
Edit: Has anyone had experience with Orion HCCA152 (2ohm 15")? or the HCCA154 (4ohm 15")? or even the 12" versions?
Deck: Alpine 9887
Speakers: Hertz HSK165 XL
Amps: Audison SRx2, SRx4 & Alpine M350
Subs: 2x Alpine 10" Type S
The only difference is that they'll work with different amps...
If they're dual voice coil, you'll need to take the resulting impedance of both coils together to picking an amp to power them. Examples:
12" sub 2 x 2ohm voice coils: I could wire it in series and achieve 4 ohms (suiting most amps just fine, albeit at low power/low heat. I could also wire it in parallel for a resulting impedance of 1ohm, suitable for most mid-high end monoblock amplifiers. The amp driving it will typically use a heap of current, but with the payoff of a lot of watts coming out of the subwoofer end of the amp.
12" Sub 2 x 4ohm coils: Series for 8ohm (you wouldn't do this in a car typically), or in parallel for a 2ohm load (about where you'll find most subwoofer systems run at, and amps able to drive 2ohm are quite common).
Seeing as you don't have an amp yet, I'd go the 2 x 2ohm woofer, run it in parallel, and buy a 1ohm stable monoblock, it's the most bang for buck. Differences in SQ between all these setups would be non-existant, if not in-audibly minimal. Your biggest SQ influence will be in your subwoofer enclosure, your sound deadening, and your front stage quality/mounting/positioning (plus how well your front stage meshes with your low end).
Check out my VP right 'ere!
camstatic basically explained it all
No SPL difference if both have the same power.
Lower impedance (ohms) causes amplifier damping factor to go down, which IN THEORY does reduce SQ by a small amount. Say an amp has a damping factor for 400 at 4 ohm, it will drop to 200 at 2 ohm. But if you have a 2 ohm sub, then you buy and amp with a damping factor of 400 at 2 ohm. Those numbers are just an example.
okay i just read this so how would a dual 4ohms 600rms sub go with a alpine mono block at 1000rms at 4ohms and 2ohms?
Vy ss sandman, bringing back the past![CENTER]
You guys are crazy, how do you suggest running a subwoofer if you don't even know a model number?
My sub (hifonic 2412 rated 2400rms), Alberts said they wouldn't wanna put more than 1700rms into it. Would you suggest putting 3000rms into it? It would shatter it I recon.
For all you know it could be like a black and gold brand sub :P
Deck: Alpine 9887
Deck: Alpine 9887
The sub ryan626 will be using is a SPL Dynamics XTR Series 10" (XTR250D4), rated at 600wrms.....but i KNOW it will handle much more with ease, i run over 2000w into 15" versions of this sub (1000w) for ages now, never do they even get warm or show any sign of being overpowered.
150db in a commodore =
haha thanks for the help holdenboy , once again! i was just curious
oh and for you others , im running a pdx 1-1000 alpine amp for the sub
definitley not crap gear
also running four component mb quart speakers with tweeters of a alpine pdx 4-100
