Results 1 to 8 of 8
Thread: VE Speaker Wiring
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Default VE Speaker Wiring
    Hey guys,
    Ive got a VE to install a LOC/amp/sub into, just wanting to know if anyone has tapped into the speaker wires to wire up the LOC, (btw the car is a ute so only front speaker outputs?) If so, what colours are the wiring?
    I realise ive gotta pull off the drivers side of the centre console to access the stereo plug, but didnt wanna risk testing wires and thought some nice person would make this part of the job a little easier......also how did you go about remote power for the amp, just wire it to accessories or is there a wire that powers the stereo i can tap into?
    Cheers for the help in advance
    150db in a commodore =
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    OK well i found the wiring colours (lol)....
    Just in case others want to know:
    *Remove drivers side centre console panel
    *You'll see a black plug on the "side" of the stereo, this is your speaker outputs and constant 12v+.
    Dark Green - / Light Green + = Front Right Speaker
    Grey - / Brown + = Front Left Speaker
    Light Blue - / Dark Blue + = Rear Right Speaker
    Yellow/Red - / Brown + = Rear Right Speaker
    *Also, just below the black plug is a white plug with 3 wires in it and not connected to anything, this is a good source for accessories (Brown / Yellow wire) and earth i suppose (black wire).
    kgb
    kgb is offline
    2009 VE SSV Ute
    Apr 2009
    Do you have any pictures of the job? I'm wanting to do the same thing but not sure where to start.
    VE Lumina
    Mar 2004
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I havent done the job yet, just got two VE utes to do in the next week or so, and wanted to do some research to make the job a little easier
    Apparently the panels pull apart and go back together like lego?? lol.
    ve ute 22's lowered hardlid
    Apr 2009
    newcastle
    VE Lumina
    Mar 2004
    Mate, its all pretty easy actually. Everything is just clipped together. You start with the big plastic bit under the steering wheel. Just firmly pull on the bottom of that (bottom obviously being down towards the pedals) and you should hear it click and feel it come down etc then do the same for the upper bit of it and it should come straight off. Then its the same for the plastic bit that covers all the wiring behind the H/U. I think it has a clip or two up the top of it and thats about it.
    So yeah the key is to apply firm pressure to the panels and the clips will unclip. (eg don't just yank at it you will probably break the clips)
    Apr 2009
    newcastle
    cheers mate. yea thought it jus unclipped like it does around the front centre speaker, but didnt wanna break no clips lol.. cheers
LinkBacks (?)
  1. VN Rear Speaker Wiring
    By Rustyone in forum Car Audio
    Last Post: 02-10-2006, 11:16 PM
  2. Speaker wiring to amp
    By tr3nt in forum Car Audio
    Last Post: 21-03-2006, 10:16 PM
  3. vt door speaker wiring.
    By ciaranvt in forum Car Audio
    Last Post: 12-01-2006, 09:43 AM
  4. Speaker Wiring Help
    By mk3_1 in forum Car Audio
    Last Post: 19-06-2005, 02:51 PM
  5. Where does the Rear Speaker Wiring go?
    By Darkwander in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2005, 04:25 PM
