Results 1 to 14 of 14
Thread: Alternator Whine (rear speakers only)
    97 VS Executive
    Nov 2008
    Default Alternator Whine (rear speakers only)
    I have noticed issues with alternator being posted already and have tryed all the suggested solutions in them. The thing about my problem is the whine is only comming out through the rear 2 speakers, when I unplug the amp running those speakers, the problem is gone. Thing is, i've tryed 3 different amps, 2 different speakers, changing the grounds, and still I get this noise. Any ideas??
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Simple solution.....run the rears off the head-unit
    Seriously, you may need to look at the power/RCA side of things......do you run any other amps off the same power cable? RCAs?
    150db in a commodore =
    97 VS Executive
    Nov 2008
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Do you have another amp/power cable in the car?
    If so maybe try using that power cable to power your rear speaker amp. If that dosent work then try using the RCAs off the other amp....if this set is running a sub then you may have to turn off the LPF on the head-unit or swap the RCA over.
    What head-unit are you using?
    97 VS Executive
    Nov 2008
    sorry i made a mistake, i'm actually running 2 amps both off the same power cable 1 for the sub 1 for the speakers, i will try swapping the rca on the head unit now
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah that might be a good idea......you still might have problems with the power cable etc, as the noise is cut from the sub by the LPF.
    Head-unit brand?
    97 VS Executive
    Nov 2008
    ok so i just changed it over then, it actually made the whine louder, like twice as loud.
    brand is pioneer
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Ahh, could be the earth fuse inside the head-unit then.
    97 VS Executive
    Nov 2008
    true. I dno what that is lol
    I'm prolly jst gonna take it to the shop, i've had it with this problem
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    yeah, its something you dont wanna mess with if your not too confident in pulling apart the stereo.
    97 VS Executive
    Nov 2008
    VR 5L
    Jul 2006
    Yeah its a blown earth fuse, My pioneer is the same, There is any easy way to test it, Ground the H/u To the outer metal off the RCA's. If the sound go's away then thats your problem. Costs about $60 to get fixed from pioneer.
    97 VS Executive
    Nov 2008
    97 VS Executive
    Nov 2008
    that was it, thanks for input
    replaced the headunit, sounds sweet as
  1. Replies: 2
    Last Post: 04-09-2008, 08:18 PM
  2. alternator whine in stereo
    By impulsesv6 in forum Car Audio
    Last Post: 03-02-2007, 12:36 PM
  3. Adventra Rear end whine.
    By Kartbro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-01-2006, 11:05 PM
  4. alternator whine, filters arent working.
    By mwethereld in forum Car Audio
    Last Post: 21-08-2005, 09:41 PM
  5. Alternator Whine
    By cycom563 in forum Car Audio
    Last Post: 01-02-2005, 09:58 PM
