Results 1 to 5 of 5
Thread: Wiring & Amp Upgrading - Have i made any mistakes?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Default Wiring & Amp Upgrading - Have i made any mistakes?
    Hey guys,
    though the advice i've got on here i'm upgrading my amplifier wiring in my car so i can run another amp. Just wanted to check i'm doing it all right before i go and buy the stuff.
    4AWG power cable
    4AWG earth cable
    into two distribution blocks
    then 8AWG power/earth cable to both the amps
    what sort of fuse will i need now?
    My amps are 500wrms at 2 ohm monoblock
    240wrms at four ohm four channel
    total of 85amps of power
    thanks, please let me know if i've made any mistakes
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    I would run the following cable> Battery terminal> 4 gauge > fuse (80amp)> 4 gauge > Fused Distro (fuse each amp individually)> 4 GAUGE to BOTH AMPS
    Ground will be 4 gauge from both amps individually.
    8 guage is way to small for a 500wrms, and depending on the amps i wouldn't suggest it for 240wrms either.
    Also why are you running 2 distro blocks? wouldn't that make at least 4 outputs for 2 amps? or are you using one for ground? i wouldn't recommend doing that unless you are doing 4 guage> distro block. 1/0 guage to ground point.
    Dec 2008
    i'm pretty broke haha and trying to keep costs down. a while ago holden boy said it would be okay to run 8gauge to each amp, i thought 8gauge was good for 100amps of power?
    i was going to run 2 distribution blocks, one for power one for ground.
    if i do what i said, and still fuse it properly, at worst wont i just not have maximum power?
    thanks mate
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by sweefu View Post
    Hey guys,
    A good rule of thumb is to add up the ratings of all the fuses on the back of the amplifiers, and fuse the main power wire with a fuse rated of that amperage or slightly higher.
    Quote Originally Posted by SMIT View Post
    8 gauge is still fine for 500wrms, what you could also do is run 4 gauge all the way to the monoblock, then a 8 gauge 'jumper' wire from the monoblock to the 4 channel.
    Also why bother with fused distro blocks? the main fuse is mainly to protect the wire and is plenty in my opinion, the amps have their own fuses.
    thanks mate
    Remember the current draw is dependent on the amps, its your job to make sure that the wiring can support that current draw. A suitably fused 4 gauge to a distro block with 8 gauge to each amp will suffice.
    Dec 2008
    Quote Originally Posted by vn6pwr View Post
    Thanks for all that help mate i might go with the idea of 4awg to monoblock then jumper to my four channel, or i'll just go witht the 4awg to distro then 8awg.
    Thanks again
  1. Stupid Mistakes
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2008, 07:23 PM
  2. Dumb mistakes cost alot.
    By Jasoniumh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2007, 10:57 PM
  3. upgrading 202 to Vn V6
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2006, 06:22 PM
  4. Upgrading a VS 3.8 to VS 5.L
    By NeilB in forum V8 Development and Modification
    Last Post: 31-01-2006, 12:16 AM
