Results 1 to 9 of 9
Thread: HELP - Double Din in a VS Statesman
    VSIII Statesman
    Nov 2008
    Katherine
    Default HELP - Double Din in a VS Statesman
    Guys, can you fit a double din DVD unit into a series 3 statesman dash. Pict included.
    Is there enough room, im guessing ill have to cut out the centre piece> Any help would be good.
    Its a AVH-P4150DVD what I want in there
    Attached Thumbnails Attached Thumbnails HELP - Double Din in a VS Statesman-08052009274.jpg
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    I guess it would be possible, but i would be thinking about clearance issues behind, doubt it would fit without allot of modifying.
    VS Calais S1
    Jul 2006
    Kadina, SA
    yeah not sure bout a statesman but i know they don't fit easily into a commodore. I tried with my Calais. The problem is that there isn't enough room even if you do cut the center piece out as there is the heater box behind it so you cant get it to go far enough back. I ended up selling my double din one to a mate and just bought a single din one with fold out screen.
    mazzstein's Avatar
    mazzstein is offline 5 Litre Owner
    VS V8 Barge
    May 2006
    Narre Warren
    possible but why bother mate?
    theres a peice of metal between the two DIN gaps which will need to be cut to fit.
    just get a single pop up dvd unit
    VR 5L
    Jul 2006
    Its possible, We put a Double Din Sony unit into a mates VR exec. Takes alot of stuffing around and we ended up having to move the heater box, Really not worth it.
    VSIII Statesman
    Nov 2008
    Katherine
    Default thanks
    thanks for the reply's guys, not what I wanted to hear though :-p
    The shop stuffed up getting me a double dinn when I wanted a single with fold out screen, but they sold me the latest model for cheaper then they bought it cause they stuffed up the quote, apparently the new AVHP DVD models are around $1300 or so though I got mine for a tad under $1000 so Im chasing someone with a single dinn (NEW) one to swap for mine or cash adjustment my way as well.
    VS Executive S2
    Dec 2009
    Default Double din DVD into VS????
    ok so ive read everyone saying that its near impossible and not worth putting a double din dvd player into a VS..... but thats the main reason why i want to get it into my car. so if anyone has done it any tips or pointers with as much detail would be greatly appreciated...
    The unit is the standard double din width and height and is 150mm Deep.
    Thanks in advance.
    Holden Vp Commodore series 2
    Feb 2009
    just have a crack, cut the space for it to fix and move the heater box else where
    Luke0011 is offline Car Audio Installer
    VZ Berlina 2005
    Jan 2007
    Its definatly not near impossible, ive done one for a normal vs dash not a stato, but its probably easier to do in a stato as the side panels sit proud of the factory stez. Basically you have to make a new panel for the climate and double din hole. Easier to do on a stato as the climate control which does not have a mechanical rod is easier to move out slightly to sit inline with the new stereo. If i had to make one for a customer i would probably charge around 300 to make a painted fascia
  1. Double Din
    By Kuka in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2009, 09:34 PM
  2. VS double DIN
    By Niggadore in forum Car Audio
    Last Post: 25-10-2008, 12:14 PM
  3. Best double din under $500
    By Gero SV6 in forum Car Audio
    Last Post: 15-10-2008, 09:20 PM
  4. vz double din
    By scolari in forum Car Audio
    Last Post: 21-10-2007, 04:40 PM
  5. VS Double Din??
    By ezytarget in forum Car Audio
    Last Post: 10-04-2005, 11:58 PM
