Results 1 to 5 of 5
Thread: Head-Unit Help!!
    VS Executive Wagon
    May 2009
    Default Head-Unit Help!!
    Just bought my first car, a VS Commodore Wagon and after putting up with a cassette player for a couple of months, today i bought a new Kenwood Head Unit, after installing it (which took me all day to do, first timer) found that i need to make my own brackets for it to be attatched in the console, just seeking experience on the best way to go about it?
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You dont need to make brackets for it, i drilled into the metal that runs down along side of where the H/U slides in, and lined those holes up with the ones on the side of the head unit.Make sure it's right, you only get one crack at it.. Pretty sure all H/U's have holes on the side, or either on the standard mounting bracket that they come with...
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah use the stock brackets off the stock head-unit, drill a hole in between the two pairs of small holes at the front of the bracket.....this should match up with a hole on the Kenwood head-unit in about the middle (height wise and about 10mm from the front).
    150db in a commodore =
    VS Executive Wagon
    May 2009
    VS Commy V6
    Jan 2008
    just use teh old brackets works a tread just dont go putting huge screws into your new head unit i just needed to angle them a bit more and no probs at all dont make it hard for your self making new ones.
  1. vx head unit
    By vx2002torana77 in forum Car Audio
    Last Post: 27-09-2008, 10:53 PM
  2. VZ head unit
    By VZ219 in forum Car Audio
    Last Post: 12-02-2007, 05:40 PM
  3. VE Head unit in a VZ??
    By scottishgit in forum Car Audio
    Last Post: 19-10-2006, 01:19 PM
  4. head unit
    By stevenwilson in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-10-2006, 06:02 PM
  5. VH SL/E Head Unit
    By daggett in forum Car Audio
    Last Post: 08-10-2004, 08:07 PM
