Results 1 to 3 of 3
Thread: VY Blaupunkt 6 stacker into VZ
    VZ Clubsport R8
    Mar 2009
    New Zealand
    Default VY Blaupunkt 6 stacker into VZ
    My 6 stacker in my VZ R8 has died and I want to replace with a factory stereo. One option I have found is a 6 stacker from a VY Calais. The unit is identical and I know it will just slot straight in but will I have any problems with the PIN and matching it from a VY to VZ. I would presume it shouldn't be a problem but has anyone else done this swap and experienced any problems??
    VE SSV Commodore
    Oct 2008
    Torquay, VIC
    Yes it is as simple as plug and play - as long as you have the correct PIN from the new unit it will perfectly. I got a 6 stacker from a VY SS in my VZ SV6. Getting a unit from a ute is the only time you'd have problems - you'd have to get the rear channels enabled from Holden - definitely worth saving yourself the effort as they have absolutely NO idea.
    Good luck.
    VZ Clubsport R8
    Mar 2009
    New Zealand
    Cool, thanks for that. I have seen a 6 stacker from a Maloo and it has a different control where you would normally have the aerial up/down button.
    Good to know a VY unit will work.
  1. [NT] Give away, Blaupunkt 6cd stacker (from VY Calais)
    By Benjamin K in forum Parts And Other Items For Sale
    Last Post: 23-02-2009, 06:20 PM
  2. Blaupunkt 6 stacker CD / Radio handbook
    By epoxpro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-01-2009, 10:08 PM
  3. WTB - Blaupunkt VY/VZ six stacker
    By Phreddy in forum Swap / Wanted to Buy / Trade
    Last Post: 24-07-2006, 06:47 PM
  4. Removing VY Blaupunkt 6-Stacker (from ute)
    By CirrusC2 in forum Car Audio
    Last Post: 16-07-2005, 07:37 PM
  5. Replies: 1
    Last Post: 13-06-2005, 10:00 PM
