Results 1 to 5 of 5
Thread: Install a single din into a VX
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    Default Install a single din into a VX
    Hi all.
    So I have built my steering wheel control to IR converter (JVC only ATM). I have successfully removed the old stereo but now I have to bolt the new one in.
    So I'd like to know if there are any good howto's about the place. Mostly I need information on how to remove the side console panels so I can get access to drill some mounting holes.
    OR
    How much (and where in Newcastle) will it get to get it professionally installed. Bearing in mind I have all the electrical bits and only need mechanical mounting.
    OR
    If there is a professional installer in the Newcastle/Hunter area that would like to swap an ir converter/ALDL/OBD adaptor for a (basic) install drop me a PM.
    Mike
    VX Lumina
    Sep 2007
    hi mate, when i put my first single din in my car, it was a pioneer, the cage that came with the deck was a bit to small for the cage already in the car so i just wedged it in there real tight (Its a real tight fit) and then wedged the deck into that cage and it stayed there by itself, not one screw. sounds a bit dodgy but worked a treat for me. would show u picks but now got a double din dvd headunit
    VK
    Jul 2004
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep the cage is a REAL tight fit, but does fit in there, i usually put a screw on either side though....but its such a tight fit you could get away without them.
    Mate im not after a converter but can the job for you, send me a pm.
    150db in a commodore =
    michaelw's Avatar
    VX S2
    May 2005
    Newcastle NSW
    Thanks, I just was not being brutal enough.
    At least this thread might help the next bloke.
    Mike
  1. 4.11 Diff Gears To install or not install
    By ScoHar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2009, 10:14 PM
  2. two single DIN in VS
    By hsvtj in forum Car Audio
    Last Post: 07-01-2009, 04:53 PM
  3. Single or taken
    By bundy_princess2006 in forum Just Commodores Polls
    Last Post: 03-05-2008, 11:11 PM
  4. single?
    By _Mukas_ in forum Jokes/Humour
    Last Post: 02-06-2006, 12:42 AM
  5. WTB: Single Rim
    By Bax in forum Swap / Wanted to Buy / Trade
    Last Post: 25-03-2006, 02:07 AM
