Results 1 to 5 of 5
Thread: SS-V Ute
    VE SS-V Ute
    May 2009
    Default SS-V Ute
    Recently got a new SS-V ute and wasn't overly impressed with the 'premium' sound system in it.
    Being a ute, I realise there's not a huge amount I can really do, apart from new fronts, an amp and a small sub. Or are there other possibilities?
    Also, can anyone recognise a good place to go in Perth for car audio stuff?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Nope, your basically right...those are your only "typical" options for upgrading the system. You could go with custom door interiors with 2 sets of splits in each door and a custom built subwoofer enclosure to maximise the cabin of a ute but theres plenty of $$$ to be spent down that route
    Just because you can only change the fronts and add a sub/amp, dosent mean you can get a great sounding system for a couple of hundred dollars.
    As far as good places in Perth go, cant help you with that one
    150db in a commodore =
    Voodoo VE SS UTE
    Feb 2007
    i Brought a VE SS ute about a month ago and i was really unimpressed with the stereo also.
    i just replaced the splits with reasonable set of 6.5inch splits and have ran them of a small two channel amp i have mounted under the passenger. It was a huge improvement over the standard system for not that much money and if i need more base i can always add a sub at a later sate
    VE SS-V Ute
    May 2009
    Cool, will replace the fronts and add an amp and a sub, hopefully that'll be enough. Cheers for your help
    Voodoo VE SS UTE
    Feb 2007
    Hey mate can you post a pic of how your sub fit once you install it?
    Cheers Jonesy
