Results 1 to 11 of 11
Thread: window rattle when volume turned up?
    djeyecon's Avatar
    djeyecon is offline black is back.
    VU Ute 3.8 S V6
    Mar 2008
    Narellan, NSW
    Default window rattle when volume turned up?
    is it my runners? can i get some dynamat to prevent this or is it because my window isn't secured properly? if i roll up my window a couple of inches the rattle goes away.
    any suggestions?
    Brux's S Pack V6 VU
    MODS:
    - 20" Jet League F-22's all round
    - Lovells springs in rear, Kings in front
    - Advance extractors
    - Custom full mandrel bent 2.5" exhaust from cat
    - Altezza head and tail lights
    - BILLET Products short shifter
    - NGK Iridium plugs
    - K&N pod
    - VIBE Black Air 6 Speakers
    - VIBE Black Air 12 Amp
    - VIBE Slick A4 Amp
    - Clarion DVD Screen
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Quote Originally Posted by djeyecon View Post
    any suggestions?
    It's normal, just happens with cars that have been around for a while...if you want to fix it properly then its a massive job taking the door and windows apart to fully adjust and reseal everything...just wear and tear of the car mate...all about friction and rubbing points
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    djeyecon's Avatar
    VU Ute 3.8 S V6
    Mar 2008
    Narellan, NSW
    fair enough. i'll deal with it for now
    Brux's S Pack V6 VU
    MODS:
    - NGK Iridium plugs
    - K&N pod
    - VIBE Slick A4 Amp
    VY2 Berlina
    Jun 2008
    Castle Hill
    I have the same. if i put my window down a smidgant, it instantly goes away. bf if i know why though.
    VY S soon to be SS
    Feb 2009
    NSW
    my cars the same. put ur window down or up a few mm and should be fine.
    live fast---drive faster
    djeyecon's Avatar
    VU Ute 3.8 S V6
    Mar 2008
    Narellan, NSW
    lol yeah clearly.. the whole point is to find a solution other than putting my window up abit...
    Brux's S Pack V6 VU
    MODS:
    - NGK Iridium plugs
    - K&N pod
    - VIBE Slick A4 Amp
    rippen50's Avatar
    rippen50 is offline Wants a Manual =]
    VY Executive 3.8L
    Apr 2007
    Camden
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    turn the volume down till i stops
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    My window used to rattle when I had it down, all the way down or a little bit. I have since had to get a new power window regulator, as the old one fell apart, and the problem is now gone. So I guess my problem was the regulator, dunno if you can check that too easy..
    gdunkley84's Avatar
    gdunkley84 is offline I Have a Dent.
    2005 VZ SV6 6SPD (HBD)
    Jan 2005
    Hammond Park, WA, 6164
    The product you want is called bailey channel and it goes in the channels on each side of the window where they run up and down. In older cars this starts to harden up and create rattles.
    It can be a prick of a job though. Probably require taking window out sometimes.
    2005 VZ SV6 6SPD - Holden By Design
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    Default vibe
    sound like baily channel to me also,new genuine is best,good 2nd hand is the cheapest(check its still softish and flexible) or you can also get universal gear but check sizing
    may pay to remove the door trim and tighten anything that may be loose first
    cheers
  1. window rattle
    By cewing in forum Car Audio
    Last Post: 18-08-2008, 12:31 AM
  2. car just turned off ??
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2008, 06:17 PM
  3. Drivers window rattle
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-12-2007, 08:03 AM
  4. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  5. Drivers Window Squeak/Rattle
    By dtrain in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-02-2006, 03:24 PM
