Results 1 to 13 of 13
Thread: just cant get it kickin
    2000 Vt series 2 S pack
    Jul 2008
    eastern suburbs, Melb
    Exclamation just cant get it kickin
    hey guys
    in my VT iv got a..
    3 rca pioneer deck,
    pioneer splits in front doors (which i think could be stuffed cos they put out all bass and no sound)
    holden speakers in the rear doors,
    pioneer 6x9s in the parcel shelf,
    12' pioneer sub in custom box,
    4 channel kicker amp powering the sub and the front splits,
    and a coustic amp powering the 6x9s...
    now to my problem...my 6x9s are running fine, got them tuned up and sounding good!!
    my front splits are jsut putting out all bass no matter how much i play with the settings on the amp or the head unit, and my sub is putting out next to NO bass and when i do get a bit of bass it is really tinny wit nothing behind it!! (my mates $200 sub in a box with nothing else sounds louder and better)
    hooked up my sub to a mates amp and it sounded fine, then hooked up my amp to his sub and seemed to work!!!
    i literally have no idea wat it is!!
    i got quoted $600+ from a car audio place to jsut have a look at it thats not even to fix it!!
    wondering if any one in the south eastern suburbs (around 3153) knows wat there doing and doesnt mind having a look ( i can pay and come to u)at it or any one can diagnose the problem over the net!!
    sorry its a bit long but its been like this for 6 months and its plain anoyying!!
    cheers
    dippa
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    If your running the 4 channel to the subs, and the splits, what's filtering the Low frequencies going to the Splits...
    Jul 2008
    i dont no wat your talking about
    lol
    i bought it the way it is and dont really no that much about stereos and that
    cheers
    Mar 2009
    Cairns White Rock
    Well firstly, is the 4 channel amp bridgeable?? because im assuming the rear 2 channels have ben bridged to run the sub.. I would have ran the splits and the 6x9's off the 4 channel, and bridged the 2 channel to run the sub..
    Jul 2008
    Quote Originally Posted by holdencommodorevp View Post
    once again im not sure wat u are talking about, i bought it the way that it is...later this arvo/maybe 2moro ill get a picture of the amp set up labbelling wat is wat and see if that clears things up aa bit!!
    cheers
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What model head unit? Some of the better Pioneer head units have "NETWORK" mode which means your RCA's output HIGH, MID and LOW rather than FRONT, REAR and SUB.
    Jul 2008
    Quote Originally Posted by StoneX View Post
    not exactly sure
    ill get those pics up and show the model number!!!
    cheers for the help so far guys
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Sounds like you have high pass filter set on the subwoofer output, and low pass filter set on the speaker output (should be the other way around). Check your RCAs are coming from/going to the right places.
    Check out my VP right 'ere!
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    doesn't sound like your going to understand what any of us are talking about...
    1. I would suggest removing both your amps and reconfiguring them like
    • Run the front splits and the rear 6X9's off the 4 Chan Kicker (4 speakers, each one running of a single channel of the 4 channels of the amp)
    • Run the sub off the Coustic 2 chan amp, BRIDGED (Bridged basically means you connect the two channels together to double the power output, BE CAREFUL because some amps cannot be bridged
    2. Look at your wiring, chances are something could be rubbing or just not done properly...
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Jul 2008
    ok cheers guys for the help..
    ill endevour to have a tinker on the weekend and see how we go!!
    ill let u no and keep asking quetions!!
    Cheers again!!
    dippa
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    have a look at the switches on the amp. there should be one saying "HPF/FULL/LPF" and there will be a spare drawn around it with the channel numbers drawn on it. So for the channel the front speakers are in, set it to either HPF or FULL, because if it is set to LPF it will only play the bass notes.
    As for the sub, try the same thing. Make sure its on LPF for bass.
    Jul 2008
    hey guys sorry about not doign anything about this thread,,
    bosses brother is an auto elec so he had a look at it and some one stuffed up the wiring once upon a time...
    had to buzz out all the cables and see wat was running wat..
    it was jsut a case of wat we thort was supposed to one cabel was something else so thats y we couldnt fuigre out the wirirng issuE!!
    cheers guys
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    is this all sorted now mate. if you need a hand in in 3170
  1. not kickin over?
    By jet_pilot in forum General
    Last Post: 04-02-2008, 07:49 PM
