Hay All
im trying to hook up a mono block amp and my sub to the original WH eurovox head unit, and just wondering how do i go about this,
can i use the original wires there or do i need to get special items and extra wires
the only wire im currently short is the "remote" wire to the amp i have the power and earth just need the 1 in the middle.
You need what is called a LOC - line output converter. They are also known as hi-low converters. Basically that take a high voltage signal in (existing/original speaker wire) and covert it into a low voltage signal (RCA's). This enables you to connect up an amp/amps.
<<<< The information went data way! >>>>
ok thanks,
so how would i go about connecting them, just attach them to lets say, the rear speaker wire and than to the amp ?
my amp has a point 4 a remote wire do i need that or will the rca from the LOC be enough 4 it ?
