as this is a semi common thing
to begin with it is only happening thru my speakers that are on my amp.
i have a noise reduction in place but its still happening
its not the normall alternator whining its just a buzzing
it goes away after 5 or so mins, but when you turn something on e.g mainly a/c, and indicators
also when you put the indicators on the sound goes thru the speakers
does anyone have any clue what it could be
i also have a earth from my seats, and a earth from the battery
Im guessing it's an earth related problem. firstly, where are you amps mounted, because if their mounted in the boot, and your earthing of the front seat, then that's too long of an earth cable to start with. You should be earthing off as close to the amp as you can.
Secondly, if you havent already done so, run your RCA's and power cables, down different sides of the car, to aviod any possible interference.
The best spot for earthing in my opinion, is to slide the top section of your rear set off, and you will notice some holes in the metal. These are great earthing points, and using the right size screw, with a nut on the other end, you can ensure a really tight connection is made..
Either way your picking up a signal from somewhere, which would only happen if some part of your wiring, is either too close to something, is touching something else, or is not sufficiently insulated. And what did you mean by you have an earth off the battery????? You should only ever be using power from the battery, and earthing from the cars chassis..
BTW how is the rest of your set up going, i remember you posting ages ago about trying to get your 6x9's into the parcel shelf if i remember correctly?
i use to have a whinning problem with the amp and speakers but solved it, when i fiddled with the settings abit, i had it set on to much bass or something..i also replaced the speaker wire with a better quality then the old dodgey stuff...
u could give it a go, if it helps![]()
Its more than likely an earthing problem, as vpcomm stated. But earthing straight from the battery is the best solution....but you can get a good earth from a solid part of the chassis so its kinda pointless running another cable from the battery.
I would make sure your earth is good, both at the amp and at the head-unit. But i'd
imagine its at the amp as your only getting it through the amped speakers.
150db in a commodore =
Another thing to consider is perhaps your RCAs have a shielding problem, considering they could be running parallel to the tail-light loom, and they're plugged in right in front of the heater box... Might be something worth looking into.
Check out my VP right 'ere!
