Results 1 to 14 of 14
Thread: help with my boot install
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default help with my boot install
    hey guy's, ive seen many pictures where people have used a peice of MDF, or simialr, on the drivers side of the boot, closest to the tail light, to mount an amp. Now it looks simple enough, but im completely hopeless when comes to calculating or figuring out the dimensions with something like this.
    So, my question is, if someone has done what i'm talking about, do you know the exact measurements you used, in order to fit a MDF peice in this section. And how did you secure it in. Thanks to anyone who can help me.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    I've never made a wall for that section before, so I'm not sure how you would go about securing it, but the easiest way I have found for measuring odd shapes like that is just to make a template out of cardboard, then trace around that onto the mdf.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by Philthy View Post
    Yes use the cardboard makes life 100% easyier . If yah had a fake floor yah could just get 2 little block with a slight angle on them and screw them into the floor, Then just srew it onto them and if yah dont i guess yah could just screw it into the metal floor , But yeh I didnt to my boot install like that so I dunno
    Mar 2009
    Cairns White Rock
    yeah ive havent got a flat floor or anything, i just need a piece of MDF to mount my mono block, I've thought about using cardboard to make a template, but once ive cut the MDF, i've got no idea on how i can secure it. I've had a good look, but still cant figure anything out.....
    VK
    Jul 2004
    if you dont want to bolt it to the car, just use velcro on the underside of the mdf. Should secure it well enough.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Have you got a pic of someone else that has done this that you can show us?
    Most will use boxes that screw through the floor... A pic will help but from what you have described, i would be looking at making a bracket and then using a metal weld adhesive to fix that bracket to the chassis... like a ledge and then bolt whatever to the bracket...
    aZk.
    VK
    Jul 2004
    I dont have any photos, but i used it to secure my old sub box to the carpet in my old car. Sure its preferable to bolt it to the floor but this method worked suprisingly well for what it was. Just use the rough side of the velcro on the mdf and it will stick to the carpet.
    Mar 2009
    Cairns White Rock
    im trying to find a picture of exactly what i mean, i remember seeing a good picture of a VR/VS white one,(mint VS supercahred the add says..) that was in the for sale section. Computers being gay though, so it could take me a while....
    Trayner's Avatar
    Aug 2008
    I was thinking taht yah could use the bit of MDf to make the board then maybe get like brackets and like insert them into a small hole in the carpet ? . I think thatt it might work
    black = boot wall/carpet
    red = mdf
    green = bracket
    Attached Thumbnails Attached Thumbnails help with my boot install-booota.jpg
    Mar 2009
    Cairns White Rock
    whats going to hold the MDF in at the top and bottom..? Im thinking get a shitload of velcro strips, and velcro the carpet thats there now to the inner wall of the car. Then cut an MDF piece, and use another shitload of Velcro strips to secure it to the carpet...If that makes sense.I just dont want anything loose or dodgy...
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Are you after something like this?
    Attached Thumbnails Attached Thumbnails help with my boot install-snc00023.jpg
    Ronald Reagan (1986)
    Mar 2009
    Cairns White Rock
    This is what i was after, so i could mount my mono block vertically on this...
    Attached Thumbnails Attached Thumbnails help with my boot install-s5000861.jpg
    Trayner's Avatar
    Aug 2008
    Quote Originally Posted by holdencommodorevp View Post
    Soz my pic wasnt to clear. but i meant cut little holes in the carpet and slide the brackets into the holes it should hold it there good
    EDIT: forgot taht yah had a vp , is the carpet held agaist the wall with little clip/screws or is it just sitting there?
    Mar 2009
    Cairns White Rock
    yeah the carpet in the VP just sits in there, its only a mould. There just a few plugs all together that hold it in, theres a few on the back, and one on either side of the wheel arches. But yeah where i want to mount it, its just a moulded peice of carpet with nothing to hold it in...
  1. Boot Install
    By cjcrow in forum Car Audio
    Last Post: 13-12-2008, 01:46 AM
  2. Boot Install Photos
    By Gobbles in forum Car Audio
    Last Post: 18-09-2006, 11:02 PM
  3. hi anyone help to install boot rods ?
    By mike40 in forum General
    Last Post: 22-01-2006, 12:13 AM
  4. Birdie's Boot Install
    By Birdie in forum Car Audio
    Last Post: 18-04-2004, 09:48 PM
  5. Birdie's Vs Ss Boot Install
    By Birdie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2004, 11:22 PM
