Results 1 to 6 of 6
Thread: WK Caprice Aerial operation
    WK Caprice
    Jun 2009
    Default WK Caprice Aerial operation
    Morning All. Had a few issues with the electric aerial on the blaupunkt premium audio set up. Some times when the radio is turned on the aerial goes to a different height but you can hear the motor in the background trying to move it, as a result the buttons on the bottom lhs of the radio control for aerial height don't work all the time. aerial will not go up or down now.
    Where do i start?
    Static89's Avatar
    Static89 is offline I Am Ironman.
    VT Berlina S1
    Jul 2008
    Sherwood QLD
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep i would say new antenna time, sorry to say.
    Dont think its the wiring as you say you can hear the motor trying to extend the antenna, could be the motor itself (new antenna) or the masts' plastic gears (either new mast or antenna).
    150db in a commodore =
    WK Caprice
    Jun 2009
    Default where is the best place for an aerial
    assuming i replace the aerial. i'm tipping holden is not going to be the cheapest. are these sorts of things available from autobarn - supercheap that sort of thing. and how on earth do you change them out?
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Holden wont be the cheapest, from them your looking at $160 retail price. EDIT: This price is based on the standard electric aerial, WH's are different because of the set level i think? Not too sure on that one, i havnt' mucked around with adjustable aerials for a while. But thats' the price your looking at. JB usually has them at $80-100 for AERPRO ones.
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Hi there,
    It sounds like the mast may be binding inside itself.... The only way to fix this is to replace the mast itself....
    My opinion would be to take it to an expert and get them to replace the mast. Normally around the $50 mark installed depending on the place that you take it to.....
    cheers
    Simon
    Lets work as a TEAM and do it MY WAY!!
  1. Cruise Control Operation
    By Gudgeon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2009, 02:17 PM
  2. Rough operation of ecotec. CAS?
    By GTP 85 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2007, 01:29 AM
  3. Electric Antenna Operation - Normal Or U/S
    By monarols71 in forum Electrical Wiring / Questions
    Last Post: 09-11-2006, 08:06 PM
  4. ex cop vz interior light, how to restore to normal operation?
    By gibbo in forum Electrical Wiring / Questions
    Last Post: 07-08-2006, 09:34 AM
  5. VL Comm valve operation
    By Comm87 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-01-2005, 02:24 PM
