Results 1 to 19 of 19
Thread: 2 outputs (head deck) 4 inputs(amp)
    VP Berlina
    Oct 2008
    Default 2 outputs (head deck) 4 inputs(amp)
    Hey guys, I have a 4 channel amp, but my head deck has only 2 RCA outputs, is it possible to connect the head deck to all 4 channels and not just 2.??
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    You will need to connect 4 inputs, to get 4 outputs. So you'll need some RCA splitters. You will need 2 splitters, so you will end up with 2 left, and 2 right inputs (at the moment you will only have 1 left, and 1 right). Then 2 sets of RCA leads, connect them to the 4 inputs on the amp, then your good to go.
    VP Berlina
    Oct 2008
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    err... I dont understand why a splitter is needed? Doesn't 4 channel mean it can power 4 speakers? 2 fronts, 2 rears.. the RCA's will be; one for fronts, and one for rears.
    I don't think any splitter is needed...
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Denno you're thinking pairs, he only has a single pair of outputs, so he needs 'Y' adapters/splitters.
    Check out my VP right 'ere!
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    I don't understand correctly either.... Doesn't he mean he has two outputs from headunit (a pair) going to amps input. The other two on the amp should be a pair of outputs to go to another amp (daisy chain). With a pair of inputs into amp he can run two pairs of speakers as it's a 4ch amp. Unless he is planning to run more then one amp then he'll need 'Y' splitters or just daisy chain amps.
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Quote Originally Posted by camstatic View Post
    My mistake
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Ray De Man View Post
    4ch amps have 4 inputs (front/rear - left/right) If it only had 2 you wouldn't have fade and/or balance controls
    As the headunit only has one pair of RCA's which are usually rear or sub output, if you plan to run front speakers you wont have fade controls if you use RCA splitters.
    Power is measured in DECIBEL
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    My mistake, I was thinking of mono amps for some reason, I forgot 4ch amps have two sets....
    Won't it be easier just to buy another headunit that has more then one set of RCA's? Or saying that, in my brothers car he has a crossover junction box as he has the VE SV6 and the stereo is built in to dash. He has front and rear fade.
    Mar 2009
    Cairns White Rock
    Won't it be easier just to buy another headunit that has more then one set of RCA's?.
    Then he would be spending $150 +, plus when all he needs to do is split this RCA lead, to get another 2 inputs. Unless OP has big plans for the stereo, with additional amplifiers, ect, then there's no need to upgrade his existing unit..
    VP Berlina
    Oct 2008
    Hey guys to help clarify I have 1 red and 1 white out put on myhead deck, and 2 white and 2 red inputs on my amp, so tomorrow I'm goin to get 2 splitters one for red and one for white so I can run all 4 channels.
    Sorry bout any confusion.
    Thanx every1 for their input.
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    Too easy mad dog, just use your gains to bring the front speakers slightly louder and you'll be in business.
    Play a song you know well, close your eyes, you want to hear them as if they're coming from an imaginary stage on your bonnet. (Of course this varies from person to person as to what sounds good) But it's usually a good measuring stick.
    VP Berlina
    Oct 2008
    Hey I put in the splitters today and connected another set of speakers, it sounds GREAT,
    I put the splitters at the amplifier end, and I'm using 1 RCA cord, does that matter?
    Mar 2009
    Cairns White Rock
    The way you've done it you should have lost your fader adjustment. I'd be splitting at the output on the head unit, then running 2 set's of RCA's to your amplifier.
  15. #15
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Holdencommonwhorevp View Post
    It would be the same
  16. #16
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Exactly, and he'll need two sets of 5m RCA cables, not to mention 1 male to 2 female splitters.
    As an alternative which allows fading is the item below.....you will need 2x RCA 5m cables though (if mounted on the dash).
    Front/Rear Fader Control - Jaycar Electronics
    150db in a commodore =
  17. #17
    Mar 2009
    Cairns White Rock
  18. #18
    VP Berlina
    Oct 2008
    Yer, the way I have it now will be fine from what I can gather, only I won't have any fader controls. Unless I get a splitter with a fader control built in:-)
  19. #19
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yep the way youve got it now is fine.
  1. replacing head deck VH Commodore
    By mrVH in forum Car Audio
    Last Post: 13-11-2008, 12:33 AM
  2. Somthings up with my head deck
    By Static89 in forum Car Audio
    Last Post: 02-09-2008, 08:51 AM
  3. Crossover inputs/outputs...
    By neel in forum Car Audio
    Last Post: 18-02-2008, 04:38 PM
  4. got my clarion head deck
    By cxcxcxvcvcvc in forum Car Audio
    Last Post: 10-12-2007, 10:00 PM
  5. mounting head deck without brackets :(
    By ilovemyvx in forum Electrical Wiring / Questions
    Last Post: 22-05-2006, 08:10 AM
