Results 1 to 16 of 16
Thread: Retro fit Parcel shelf Question
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default Retro fit Parcel shelf Question
    Hey guys, im up for a new parcel shelf after ive hacked mine up one too many times
    Now ive noticed that with either VR/VS that the factory speaker grills are closer to the cabin, than in the earlier VN/VP versions...? Can a later model shelf be fitted to the VP? and would there be much involved in mounting a 6, or 6.5, to take place with the factory grill location on it?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I would say the holes in the metal are located in different spots too if the grilles are in different spots, but i could be wrong there.
    If by install 6/6.5s into the parcel shelf you mean screwed to the metal then either way you'll be able to mount them in there but the grilles in the parcel shelf may not line up properly....their rears anyway so shouldnt be a huge deal.
    Why not just go with a VN/VP parcel shelf?
    150db in a commodore =
    Mar 2009
    Cairns White Rock
    yeah the factory holes in the metal are in a different location.. Im looking at a later model shelf so i can add some splits, but have a completely stock appearcance..But i dont like how on the VN/VP shelf, the speaker grills are so far back, i would never mount speakers there, ona VR/VS unit, the grills are much closer to the cabin. The more i think about it, i dont think it can be done. I might just look at re-trimmnig a VN/VP shelf to suit..
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    It'll fit. Its just 1 inch too short. As for speaker holes, grab a small mesh cover (from the wreckers), a dremel and some glue.
    Also you will need a VR/VS high mount stop light and bracket.
    Mar 2009
    Cairns White Rock
    hmm, sounds like a lot of work, i'm might just get a standard VN/VP shelf without the grills, and re-trim it, and just use the Sony grills....Your idea sounds good on paper Stocky, but i'd most likely **** it up lost most things i attempt. For example, i took me 3 parcel shelves to fit my 6x9's...
    VT
    Apr 2009
    make your own out of MDF, it will sound better than any stock shelf, your speakers will have a better frequency response too, if you alreay have the holes for speaker magnets cut in your chassis you wont have to buy/make pods like I did, just screw them straight into theMDF.
    see here:
    Custom Sub Enclosure Design - rough step by step - JCA Build
    [CENTER]CRAWJP - VT
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Dont all VP+ commodores have the holes as standard? I mean they have the holes but have peices of sheet metal spot welded in to cover them up if no rears were fitted from the factory.
    VK
    Jul 2004
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Mar 2009
    Cairns White Rock
    yeah they all have the 6 inch holes, some are spot welded in depending on which model you have. But is there really any point in mounting a decent pair of speakers that far back?
    VK
    Jul 2004
    Quote Originally Posted by Holdencommonwhorevp View Post
    u know the answer to that, theres no point mounting a decent pair of speakers anywhere in the back
    For rear fill i dont see why you're bothering making up custom shit to be honest
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Mar 2009
    Cairns White Rock
    i wouldn't really say it's custom... Splits are going in the back because im pissing the 6x9's off... but i just want to move the speaker location a little further forward. But i think i might just take the easy way out, and just get a VP shelf with the factory grills, and just use the factory holes and be done with it..Wont sound as good, but means i wont have to frig around with it..and i'll probably just mount the tweeters in the hoodlining retainers...
    Vy S' Ute
    Apr 2009
    hope you didn't cut up the metal shelf when you where trying to fit the 6 x 9's. quickest way to get a perminate defect. police and regency dont like cut metal, something to do with structial integrety??
  15. #15
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by CosmoVYute View Post
    I wouldnt call it perminate. But it is a structural defect. My VN has a cut shelf because the previous owner decided to install 6x9's the bad way. Im just going to make up some thin metal plates to fit over the cut holes, cut standard 6" holes out of them and get someone to weld them in. That and new shelf carpet/board = nothing ever happened
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
  16. #16
    Mar 2009
    Cairns White Rock
    Well yeah i did cut the metal for the 6x9's, but that was ages ago, before i even knew about it being illeagal ect..But i'm doing the same as Azzfox and sealing it back up.
    Yeah splits are going in the rear- WHy?- because i'm upgrading my system, and i'll be upgrading my fronts splits aswell, so rather than sell them off and take a big loss, i'm moving them to the back, where they will become the permanent rear fill, in the factory location. No complaints from the rear passengers lol...and yes pissing the 6x9's off, (sale sect if anyones interested!) have found out for sure, VR/VS shelf will not fit, plus is doesnt come in the blue, to match the rest of my interior anyway, so im just going to pick up another VP Calais shelf and use that. Just have to get the tweeters sitting nicely in the rear retainers, and i'm good to go.....
    Any one who's used the stock rear mounting location, did you use a spacer so that the speaker isnt metal on metal?? if so were the any clearance issues. I'd like to find out before i have to attempt it, as anyone who has mucked around with those pressed fibre shelves will know how much of a bitch they can be to work with....
LinkBacks (?)
  1. 23-07-2009, 12:41 PM
  1. parcel shelf...
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-05-2009, 12:21 AM
  2. VS custom parcel shelf question.
    By FATMAT in forum Car Audio
    Last Post: 31-08-2008, 05:25 PM
  3. VX Rear parcel shelf 6X9 Speaker Electrical Question
    By Decksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2006, 08:12 PM
  4. Parcel shelf
    By davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2004, 04:14 PM
  5. Parcel shelf
    By FullySik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-05-2004, 04:18 PM
