Results 1 to 3 of 3
Thread: Vr factory radio loom adaptor for aftermarket cd playa
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    Default Vr factory radio loom adaptor for aftermarket cd playa
    i have a pioneer cd playa and i want to put it in my vr. someone was telling me that you can buy a connector that plugs from the factory loom into the cd player. has anyone heard of these before/used one???
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Yep, you can buy ready assembled adaptors from Autobarn, at least. Probably get them from plenty of other places too. You just have to hope that your model of player is one that has an adaptor available.
    They're pretty cheap too. I've seen some of them for only about 20 or 30 bucks.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    OP, just know that if you do buy a wiring harness adapter, you may sometimes have to swap some of the wires around to be completely compatiable.
    Persoannaly i have never used one, as they can be a little bulky once fitted, and if your using pre-outs and IPOD connectors ect, it can get a little crammed behind the back of the head unit when re-fitting.
    For the price of the wiring harness, it wouldnt set you back too much more to just have it professioanly fitted if your unsure on what your doing.
    Otherwise, if you want to fit it yourself, there a thread located at the top of the Car Audio section page, this will give you the wiring diagram you will need to connect your Aftermarket headunit, to your factory harness.
LinkBacks (?)
  1. 20-08-2009, 09:49 AM
  1. Aftermarket CentralLocking + Factory Immobilizer
    By anarklov3r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 07:20 PM
  2. Upper control arms on VN Diff aftermarket or factory?
    By Bz Kn33z in forum General Discussion
    Last Post: 05-03-2009, 06:02 AM
  3. who's got the factory radio in there vl?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-05-2008, 06:03 PM
  4. VC Factory radio
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2007, 09:44 PM
  5. aftermarket parts and factory warranty!
    By jp77 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 18-02-2007, 04:22 PM
