Results 1 to 14 of 14
Thread: Sub and amp install | how to
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    Default Sub and amp install | how to
    just wondering if anyone has a how to guide to installing subs and amps properly.
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    I could give you s step by step guide.....but you'll have to be experienced with car audio gear installation and pulling apart certain interior parts of your car. If not its far better to head into your local car audio shop and pay them to install it, should cost around the $100-$150 mark i'd imagine, more for the cables required if you dont have them.
    150db in a commodore =
    eXphoid's Avatar
    eXphoid is offline I have no license yet xD.
    VZ executive & VS Equipe S2 Ecotec
    Dec 2008
    VIC
    Every car is different, so the method is similar but different in its own way. Don't go to a specialist yet though, just keep asking as some people are willing to install it for a 6 pack or something.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Chris if you have a fair idea on what your doing, then i reccomend just getting stuck into it, and if you have any problems along we way, im sure you'll get the answers on here. But like Holdenboy was saying, you'll need a bit of knowledge and experience, so if you haven't got that, then take it to a specialist.
    VR 3.8L
    May 2009
    ive installed a cd plaer sub and amp in my old pulsar so i know a bit but i actually care about this car so i want to do it properly without blowing speakers etc.
    gdunkley84's Avatar
    gdunkley84 is offline I Have a Dent.
    2005 VZ SV6 6SPD (HBD)
    Jan 2005
    Hammond Park, WA, 6164
    Maybe posting what gear you have might get a better answer. We could probably drum up a step by step guide.
    2005 VZ SV6 6SPD - Holden By Design
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Well if youve got some knowledge (sounds like you do) then yes, we can provide you with a guide on what to do. But youve already installed a sub and amp before, so you should know what to do?
    Anyways yeah like above just post up the components you want to install.
    VR 3.8L
    May 2009
    sub and 2 amplifiers...can you run 2 amplifiers by commoning one fuse?beacause i dont want to have one fuse for every amp i run
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    You will need a fused distribution block, so you will have a fuse at the battery, then 2 in the distribution block. This is one area that you don't want to cheap out on coz a fuse is all thats between your dodgy wiring and your car becoming a fireball
    VZ Wagon
    Jul 2005
    I mounted a 4 channel amp under the seat of my vs, was a little large and fasioned a cover plate sort a of a Z shape to look at it from the side, then attached it to the floow and the amp with velcro, stopped people kicking the amp.
    Another point to think about: is there any specific point to run the amp power cable through the firewall that is easy. Remember it was a pig of a job in my VS and took ages to finesse it through, and hoping someone has some ideas on how to do it in a VZ, whether there is a spefiic spot to go through
    gdunkley84's Avatar
    Jan 2005
    Quote Originally Posted by kinga View Post
    My power cable runs up and across the engine bay and through a small grommet behind the passenger side strut tower. There is a large grommot with part of the engine loom in there and then there is another grommet a little lower.
    VK
    Jul 2004
    theres also the clutch grommet on the driver's side if you have an auto. A little bit easier to get to than the one on the passenger's side.
    gdunkley84's Avatar
    Jan 2005
    Quote Originally Posted by bezz View Post
    Fair call couldn't find one on mine. I got a manual.
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by chrisdoesitbetter View Post
    mate run as many fuses as you want, just make sure they are all rated less than the cable.
  1. 4.11 Diff Gears To install or not install
    By ScoHar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2009, 10:14 PM
  2. vy ute sub install
    By ncc59 in forum Car Audio
    Last Post: 25-06-2008, 06:00 PM
  3. CAI Install Help
    By the_ozz_man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2008, 05:23 PM
  4. VT H/U install
    By smiley235 in forum Car Audio
    Last Post: 27-12-2006, 08:28 PM
  5. new install
    By matrix in forum Car Audio
    Last Post: 07-03-2006, 05:47 PM
