Results 1 to 17 of 17
Thread: Building a LPF/crossover
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Default Building a LPF/crossover
    I'm gunna post this in the car audio section, even though it isn't related to cars exactly.
    The deal is, that a mate of mine has an old (~10 years) no-name pro-audio 12" sub lying around, and I have a decent PA setup that I use for parties etc.
    Now, I want to build this sub a box, and use it with my PA gear for a bit of extra low-end kick, but I will need a low pass filter/crossover for it, as the amp I'll be running it off doesn't have one. Now, since this is only really for a bit of fun and I don't expect it to last that long I'd like to have a go at building a crossover from scratch, as opposed to forking out ~$80 like they all seem to cost.
    A bit of googling tells me they aren't that complicated but I'm having a bit of trouble finding a suitable schematic to copy. I was thinking of either 80 or 100hz as the cutoff frequency, and it will have to be an active design, able to cope with up to 500wrms, but usually only 250wrms.
    I found a table that says what capacitor and inductor I want, which I will be able to get from Jaycar
    Frequency 2 ohms 4 ohms 8 ohms
    (Hertz) L C L C L C
    80 5.6 mH 700 µF 11 mH 330 µF 22 mH 180 µF
    100 4.5 mH 550 µF 9.1 mH 270 µF 18 mH 150 µF
    http://ccs.exl.info/cust_cr.html
    The problem is that there are so many designs that I don't know which one is the best!
    http://www.discovercircuits.com/PDF-...wPassFilt1.pdf (a few designs)
    Does anyone on here know anything about this sort of thing? Just a simple schematic should be all I need to figure it all out
    Philthy's Avatar
    Aug 2005
    Sorry, turns out I don't know what I'm talking about and it's actually a passive XO that I am after (Post amp, between the amp and the woofer)
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by daron View Post
    why
    set ya amp at the right settings youll never need to change it
    The amp I'm using is a 2ch PA amp. I'll be running 2x12in boxes off one channel and the sub off the other channel. It ha no filters as such, just a graphic eq for each channel.
    I have it figured out now I think...realising that is was a passive filter I needed makes it easier. I'll make a 2nd order (12dB/octave) LPF with an 18mH inductor and 135uF (probably more like 133uF) capacitor. I find slightly different values wherever I look but that combination should be relatively easy to make using bits from Jaycar and the like.
    Slippy_Trippy is offline Unicorn Shepard
    1999 VT II Commodore Acclaim
    Jun 2009
    Melbourne, VIC
    Yeah all parts easily available at Jaycar, they even have kits I think. You could also just look into a Behringer XO unit. Not the nicest prospect in the world but they work well and are adjustable which could come in handy when you tune your PA.
    -Trippy
    VK
    Jul 2004
    wow that first website oversimplifies filter design way too much. There's a lot more to it than that.
    As for the designs on the second site, they are all variants of the same type of filter. A butterworth filter is good if you want there to be minimal fluctuation in the pass band just before roll off. Problem is Butterworth filters have quite a long roll off which may be (or might not be) detrimental to your application. Also none of those filters will be suitable for your application without modification.
    Finally, if you design your filter to use op amps instead of inductors it will make for a much more robust and smaller design, not to mention less susceptible to outside interference. Inductors are annoying to use due to windings being fragile, especially if using air core type. This is the Sallen-Key method, very common in design of filters. All of the circuits on your second site are an example of this.
    IMO do a lot more reading before attempting this. If I was designing a crossover for audio purposes I'd most probably look to using a Bessel filter.
    VK
    Jul 2004
    One more thing, you might need to consider that your amp wont be very efficient when playing back just these low frequencies. A lot of PA amps tend to be focused to deliver most of their ouput at higher frequencies (mid bass, mids to high etc). You might even find that the output <80Hz will sound closer to what you would expect from less than 100w rms from a dedicated sub amp. It may be worth considering investing in a dedicated sub amplifier instead.. jaycar do an interesting looking one but then they come at a price.
    Philthy's Avatar
    Aug 2005
    The way I understand it (and bear with me, I've never had to know any of this until now) is that active crossovers, such as in that second website, are for use pre-amp as they are more sensitive to power but will sound better.
    The passive crossovers (like I plan to use) I thought were for between the amp and sub, so they have to handle large amounts of power, and there were less design options (1st, 2nd order and so on only)
    I realise that my amp will be less efficient, but I would probably only use this sub when doing small-mid sized RnB parties and the like, where my current 12"s can't handle the deep bass. They are fine for techno, hardstyle etc, just struggle a bit on the really deep stuff, which is where I thought this sub could give them a bit of a boost.
    I don't really do enough RnB parties to warrant buying a seperate sub amp just yet, and if I get to that stage I think I would just buy a powered sub anyway.
    Jun 2009
    Melbourne, VIC
    Powered subs are a good way to go to expand your system and they generally have parallel outs which have inbuilt crossovers for you to plug your mid/high speakers in.
    If your other 12's can't handle the deep bass then chances are this no name will yield similar results, you will just pick up a few (less than three) dB because of the 1 added speaker.
    Better off to save and get a 15 or 18 powered sub designed for PA IMO. Ebay and second hand is good if you can't fully justify.
    -Slippy
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by Slippy_Trippy View Post
    -Slippy
    You think?
    I figure since this new sub I'm getting is an actual subwoofer, as opposed to full range 12s that I already have it will be able to give a better bottom end kick, and for the $20-30 that it will cost me to set up and get running it can't hurt to give it a shot.
    Plans down the track are for 1 or 2 15" powered subs, but as I said before I just can't justify that cost just yet
    VK
    Jul 2004
    I don't think that a filter being active or passive accurately reflects the quality of the output signal. If one is designed and suited better to the application than the other, then it will sound better. However, both can be used to perform the same task, and I'd recommend going down the active route using op amps, due to the reasons I mentioned above. A good starting point to get a better overview would be these wiki articles:
    Active filter - Wikipedia, the free encyclopedia
    Sallen?Key topology - Wikipedia, the free encyclopedia
    VK
    Jul 2004
    Quote Originally Posted by Philthy View Post
    You think?
    lol reminds me of the time i used a 10" dse sub with built in 150w rms amp with a couple of mackies at a birthday party. Due to the sheer volume of the mackies you couldnt hear the dse sub distorting so much.. actually didnt sound too bad! Of course it was no substitute for using 1 or 2 of those mackie bass bins instead....
    Philthy's Avatar
    Aug 2005
    Quote Originally Posted by bezz View Post
    Hmm...so where can I get op amps from? It seems that might be an expensive way to go about getting a free system upgrade.
    I assume active filters can be used post-amp as well?
    VK
    Jul 2004
    you might be right.. not sure on how much an op amp would be that would handle that much power. I know that low power op amps can be as cheap as a dollar or two. I'm guessing increasing the power handling will probably increase the price at the same rate. You might have the same problems with the other components too. I'm not too sure as this isn't really my area of expertise
    try Farnell Australia | Australia
  15. #15
    Jun 2009
    Melbourne, VIC
    Didn't realise your current 12's weren't subs, my bad. Yeah should get you a little more low end but if you are outside of in a big room it will leave alot to be desired.
    Op-Amps are easily available from Jaycar or online (DSE are cutting down their component range and are therefore useless
    Schematics and how to read them for crossover networks are also easily found with a quick good. Could be good to do a quick read on crossovers (not what they do as you clearly know that, but more how the work and the different kinds)
    -Slippy
  16. #16
    VR II Executive Manual
    Apr 2009
    ESP Projects Pages - DIY Audio and Electronics - Crossovers and Effects - One of the best resources around on active filters.
    No, you can't do active filters post-amp, they simply don't work that way - they ARE amplifiers, just typically unity gain (that is, they don't make things louder).
    As to building passive filters - um, don't, if at all possible. Inductors with that kind of power rating are very, very expensive, and decent capacitors that size aren't particularly cheap either.
    If you do decide to work your way up to an active filter, the opamp you want from Jaycar is an OPA2134PA - considered "ordinary" by audiophiles, but an excellent opamp to everyone outside the golden-ear brigade. It's certainly the best opamp Jaycar sell, and it will cost you something like $7.
  17. #17
    Philthy's Avatar
    Aug 2005
    Thanks for that Seeker, I'm finishing up exams today so I'll have time this week to head down to Jaycar and start getting this all sorted out
  1. where to put the crossover?
    By ephect in forum Car Audio
    Last Post: 26-09-2009, 11:41 PM
  2. Where to put crossover for tweeters in car???
    By Semtex in forum Car Audio
    Last Post: 08-11-2007, 07:02 PM
  3. Crossover question?? + Sub Q
    By MikeVXSS in forum Car Audio
    Last Post: 19-03-2007, 10:27 PM
  4. Crossover Problem
    By vtwgn in forum Car Audio
    Last Post: 19-03-2007, 01:20 PM
  5. damages crossover
    By yobbo88 in forum Car Audio
    Last Post: 12-08-2006, 12:08 AM
