Results 1 to 5 of 5
Thread: Sub Upgrade, Less Drone
    Slippy_Trippy is offline Unicorn Shepard
    1999 VT II Commodore Acclaim
    Jun 2009
    Melbourne, VIC
    Default Sub Upgrade, Less Drone
    I am looking to upgrade my sub which is a no named thing I got for $40. Whilst it does the job quite nicely, being a cheap 12' it is fairly droney. I tried out a 10' Kicker the other day and it seemed to give me that really nice tight kick but without the really low stuff (obviously due to the smaller cone)
    My question is, is there a compromise between lower frequency response and drone? Seeing as how I love some kick drum in my sub and not much else (just want the punch) would I be better of with a mid quality 10 or a higher quality 12. Suggesstion welcome.
    -Trippy
    VZ Executive
    Nov 2008
    the size of the sub has much less bearing on the sound in comparison to box design.
    get the best sub you can afford and then build the right box for it for what you want
    Jun 2009
    Melbourne, VIC
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Quote Originally Posted by 2LOUD2OLD View Post
    But how do you judge the best sub you can afford? By getting the (in this case) the tightest, punchiest one you can find.
    Line up an identical 10 and 12 next to each other, running ideal power in ideal sealed boxes and 9 times out of 10 the 10 will give quicker response and tighter bass.
    Slippy Trippy, if you aren't after massive boot shaking low down rumbling bass then I don't see any reason you would go a 12" over a 10.
    Spend a bit of time designing the box and a decent 10" should give you the punch you are after
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You go a 12 to get more low end and overall output. A decent 12" sub in a good box will give you all the "punch" you'll ever need.
  1. VR to VS BCM Upgrade
    By Bilbs in forum Projects
    Last Post: 16-11-2010, 08:12 PM
  2. exhaust drone
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 09:43 PM
  3. Sound Proofing Exhaust Drone
    By Calais57 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-06-2009, 08:38 PM
  4. Drone advise please :-( lukey extractors & Sports exhaust, will a Resonator help
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2008, 09:12 PM
