hey i got a ground loop isolator, and it worked a bit, but another question, i have to split my rcas 3 times, i have one comming from the head unit, and then i split it so that i have 2 for my 4 channel amp and 1 for the sub, the question is: will the ground loop isolator be sufficiant to use before i split the rcas or do i need an individual ground loop isolator for each split i have created?
You shouldnt need a ground loop isolator period. Ive been installing amps for over 10 years and never used or needed one.
150db in a commodore =
hey, thanks, i just tested the ground loop isolator with just one set of rcas plugged in, and the buzz is still there. could there be a problem with the amp itself or what else can cause distortion in the midrange?
What head unit, amps, etc are you using?
If you've got the gains on the amps turned up too high, you'll get hissing noise. Also, if your power wires and RCA's run alongside each other at all - even for a metre or so in the boot, then combined with gains too high, you'll get interference from that. That's all I can think of at the moment..
to expand on holden boy, try removing the source to see if the loop is in the h/u or amps. next try a different source unit (CD, old h/u, whatever) Once you are sure it is a component, make sure none of the chassis is touching the cars chassis. then if it is still there try a new ground or even use a seperate car battery to power the h/u for clean power.
mate just try thanging components. There is no "easy" way to do this.
