Results 1 to 11 of 11
Thread: quick question regarding head units
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    Default quick question regarding head units
    hey all,
    i was just wondering if someone could explain all this crap that Pioneer tell me about their head units. Basically they say the come with a 50W x 4 MOSFET amp built in but 50W is still not really enough to pump up my 200W speakers.
    This might sound like a stupid question but i am honestly confused.
    Cheers in advance guys,
    james
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Whats the question? is 50w going to power my 200w speakers properly?
    Short answer, yes the head-unit will power your speakers fine.....you might not get every little bit of volume out of the speakers.
    150db in a commodore =
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    ok for arguments sake lets examine the Pioneer DEH-3100UB found here: http://www.pioneer.com.au/Products/C...%203100UB.aspx
    "Built in 50W x 4 Channel High-Power MOSFET Amplifier
    To minimize voltage loss in its head unit amplifiers, Pioneer built-in high-performance Power MOSFET integrated circuitry into all its head units. The MOSFET amplifier processes signals more efficiently at 50W x 4 maximum total output. This reduces distortion to virtually nothing at high frequency ranges giving you great clear sound. "
    is what it says on the page but that wont give me the best sound quality right? because the 50W is only a quarter of what my 200W speakers are capable of running. Also, how do i find out how much wattage the HU puts out? or is it just the 50W from the amp?
    does that rephrase it properly?
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    Yeah mate sorry i didnt understand you in the first post.
    Basically youre right, but you will only hear a minor difference by purchasing and installing a 200w per channel amplifier. But then the difference in sound wont justify the cost of the amp / wiring / installation.
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    50watt per channel, is the maxuimim out put, (or it's peak power PMPO) of the Head units built in amplifier. In terms of RMS (root means square) or it's nominal/continous output, would be around 12-15 watt's RMS per channel.
    Subaru Liberty
    Feb 2007
    First thing, that headunit will not put out 50 watts ever. It is the theoretical maximum, measured in PMPO. Only when playing certain test tones will you get this.
    Secondly, are your speakers 200 watts PMPO MAX or RMS? There are not many 200wrms speakers out there.
    Most likely, your speakers are somewhere in the range of 20 to 30 wrms, and the headunit will only do 13 to 18 wrms.
    You can run 100000000 watt speakers off 10 watt amplifiers. Wattage isn't everything when it comes to audio.
    So yes, you can run your speakers off the headunit, and yes it will sound fine.
    <<<< The information went data way! >>>>
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The Pioneer head units are 22Wrms.
    As the others have said, the head unit's internal amp will run any speakers (4ohm+)... It just won't run them as well as separate amplifier.
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    cheers for your answers so far and the speakers are 200 watt max im pretty sure but like anyone else i wanna get the best i can out of them without breaking the bank.
    Also speaker wise.. what is the best value for money coaxials? i dont really want splits but any suggestions would be great.
    Mar 2009
    Cairns White Rock
    Regarding your coaxial question, are they for the front or rear? what size speakers are you looking at, and will the be amplified?
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    at the moment it will be run of the head unit and they will be 6" possibly 6.5" if they fit and preferably splits because i know how to install them. The head unit from pioneer has a 50W amp in it though if that means anything and they will be front door speakers. i already have a cheap pair of 200w rampage 6" speakers in the back which i might upgrade down along the track
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by holdenboy View Post
    Um... actually generally a pair of $150 speakers amped will sound better than a pair of $400 speakers running from the h/u.
    Also worth while to note that a h/u can easily fry both the $150 and $400 speakers if you make it clip.
    Also, you will have it around 6db louder, so the speakers will be noticably louder, have less distorsion and finally you will have less chance of a drunk mate ****ing them from turning the sound up too much...
  1. Just a quick head unit question
    By maff27 in forum Car Audio
    Last Post: 02-11-2006, 03:40 PM
  2. JVC head units
    By Calais3800 in forum Electrical Wiring / Questions
    Last Post: 22-09-2006, 08:45 AM
  3. Head units?
    By scotto in forum Car Audio
    Last Post: 14-01-2006, 02:31 PM
  4. VZ Head Units Help!!
    By bdcmedia in forum Car Audio
    Last Post: 29-03-2005, 01:55 AM
  5. Vl Head Units
    By Troy711 in forum Car Audio
    Last Post: 26-01-2004, 08:00 PM
Tags for this Thread
