Hi everyone ,
First time poster and long time lurker, Wanted to say great site but also ask a question.
I have just replaced the H/U in my VT SS with a Pioneer Deck. Setup is not using amps just the head unit and a few speakers. HAving no changed out the deck, the aerial now doesnt function ( Up and Down) im wondering if it is possible to use the remote power cable from the deck that usually switches on an amp to fire up the antenna when the car / head unit is switched on.
I understand that it will stay up during cd and ipod use. Then hoping that it would retract when the deck is turned off completely. If this is the case can someone tell me what wire to connect the remote switch wire from the deck to?
Ps the original wiring loom harnes is not their but i am assure all of the wiring is.
Yeah mate you should even have a power antenna wire coming from your head-unit as well as a remote turn on wire.
Have a look in the VK-VZ wiring colours thread at the top of this section, it should have the wire colour for the power antenna (the "up" one i beleive).
150db in a commodore =
So all i would need to do is wire the blue - Remote amp wire to the Up Aerial wire and the Aerial will go up when the Deck is powered on and then down when the deck is powered off?
Shows you how much attention i pay when wiring Pioneers up, lol.
thanks guys got it all sorted.
you can put a switch inline with this wire so when u need it, fire up the airel then wen not in use u can put it down, thats what i did anyways works a treat, save drivin round with the aireal up when u dont need it lol
ive got a on off switch in the hole where the boot release switch normally goes on the sedans, fitted perfect
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
