i have a noise coming from my speakers with music turned down iv ripped stuff apart just wondering if anyone knew exactly what it is i was thinking earth wire in head deck ...
VS Stato
Soundstream Comp series throughout with 2, 12' subs, 1 4channel amp, 1 mono block, 2 6' splits in front and 6'9 in rear pushing out 148DB. also now running a 2.5 farad capacitor .. and D34 Yellow top
1/4 mile : 593RT Running 15.9's with cat back Exhaust
REGESTER HERE FOR FREE MONEY
What head unit do you have?
What is a "compositor"?
What is a "fared"?
its a alpine not sure wat model
and sorry stupid spell check ment to say 2.5 farad capacitor
im pritty sure its the earthwire in the headdeck just want a second opinion
VS Stato
There's a few things that can cause alternator whine...
- Broken ground between amp and head unit (in RCA line) - The RCA links the head unit and amp grounds together so if the ground in the RCA is broken or RCA not pushed in all the way, it can cause noise
- Bad ground on head unit or amp
- RCA's too close to power cables
- Faulty alternator
VS Stato
Even if power and RCA cross each other at the back of the car, they can induce noise. But it soudns like your problem is probably a grounding issue.
yer im thinking its the earth in the head unit
VS Stato
Found out it s earth wire in the head uit replaced te unit and nose gone WOOT thanks r ur suggestion anyways
VS Stato
