gday
im running the 2 stock tweeters at the front of my VS, 2 on the pillar between front and back doors and then 2 are installed in my 6x9s.
is this affecting my sound quality? coz it sounds a bit off
a bit off how exactly?
aslong as youve got the midrange and bass to back it up it should be sweet
You shouldn't have tweeters on your B-pillars, they're right next to the listeners heads and will completely stuff up the sound stage. Stick to speakers in front and behind (if you have to), but none by your side.
Wow so many tweeters! Generally you only need 2 up front, some people run 2 at the back as part of rear fill.
<<<< The information went data way! >>>>
