Results 1 to 13 of 13
Thread: Tips on applying vinyl ??
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default Tips on applying vinyl ??
    Has anyone has any experience with applying vinyl to speaker pods? If so, would you be able to offer some advice for me please? I'd like the vinyl obviously to be smooth without any creases or wrinkles, as they would be if they were purchased like the pre-fab ones..When i apply the vinyl, should i start from the topdise(where it's smaller) or from the base?
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    You will need some bonding adhesive and a hair dryer or heat gun to help mould the vinyl.
    Also, what is the vinyl like, stretch wise?
    My new ride with some upgrades.
    www.teamfusion.info
    Head unit: Fusion CA-CD500 Front Speakers: Fusion PP-CM650
    Rear Speakers: FusionPP-FR6520 Subwoofer: Fusion PP-SW120 Amp For Front And Rear: Fusion PP-AM120040 Subwoofer Amp: Fusion PP-AM300010
    Mar 2009
    Cairns White Rock
    I'll see what its like to stretch, but thats basically what i was thinking on how to do it.It's just general upholstery vinyl from clark rubber.. I've got the adhessive and everything ready to go, i just dont want to butcher it lol. Im thinking i might just glue the top centre piece down to start with, and see if i can stretch the vinyl into a bit of a mould before i begin.
    VS 97 Series II
    Oct 2007
    Whalan, N.S.W
    Yeah give that a go, then you will have a hold so you can work the vinyl. Heat will help mould the vinyl around curves.
    www.teamfusion.info
    VR V8 S pack Ute
    May 2005
    I did my speaker pods in the vl on a 40 degree day. I wsat in the sun and used contact adhesive. You coat each side, put them together then pull them apart until the glue tacks off, then stretch away and glue down. I had staples down the back of mine too, so did one side of those first, so i basically stretched and stapled.
    Also the corners need to be cut to avoid the vinyl bunching up on a visible surface. When u cut the slits for the corners, really take your time, and do it bit at a time, otherwise you'll end up with a vidible cut.
    cheers,
    -smurf
    Mar 2009
    Cairns White Rock
    yeah i had 5 attempts at it, failed each time. I just couldnt' get it neat, and i'm very fussy. I ended up using some fabric instead, was a lot easier.
    Attached Thumbnails Attached Thumbnails Tips on applying vinyl ??-photo0217.jpg
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    try sticking the vinyl in the oven for 5 mins or more. could work.. Don't **** it up but lol
    There is no such thing as stupid questions, Only stupid people.
    Mar 2009
    Cairns White Rock
    Too late, pods are trimmed now lol, doesen't matter though, i reckon they turned alright
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    ohh oops my bad didn't realise ur the op...
    edit: off topic... but did you get the part# for the trim clips in the other thread....?
    Mar 2009
    Cairns White Rock
    Not yet, i not long posted it, (and it's Sunday night lol)
    Got told to try Holden spares, apparently their available there. ( and possibly Repco, most likely depending on the store) Will find out tommorow morning.
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    Quote Originally Posted by HoldenCommodoreVP View Post
    I gave you the part numbers... will make thing super easy
    Mar 2009
    Cairns White Rock
    haha, i thought you were asking me for the part number, then i realised you replied to the other post, after i'd already typed this. Thanks mate, that makes it much easier
    TrikkBen's Avatar
    BNR32
    Apr 2009
    SE, Vic
    all good :
  1. vinyl clean
    By hq-racing in forum General
    Last Post: 26-03-2009, 08:51 PM
  2. vinyl
    By eurekamad94 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2009, 06:50 PM
  3. Thud when applying the brakes...???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2006, 11:53 PM
  4. Removing and Re-Applying Side Decals
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 10:34 AM
  5. Painting vinyl in VN
    By stunnd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2005, 12:07 AM
