+ Reply to Thread
Results 1 to 4 of 4
Thread: VS II Statesman DOUBLE DIN??
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default VS II Statesman DOUBLE DIN??
    I've read mixed opinions on this. most people say it cant be done without modifying the heater box, yet i've seen VS Statesmans for sale advertised with Double DIN units in them? I know for a fact that I had a flipout screen in the top part of my VR SS, with the head unit in the lower part. So in theory a double DIN should fit fine? does anyone know for a FACT that it won't fit? As in has tried and failed? I'm not worried about the cutting of the bit in the console in between the 2 compartment im just worried if it will fit debth wise, also its a Soundstream unit if that helps. Thanks
    SENATOR
    Oct 2008
    hey dude haha, the dvd player is the same depth as any single din dvd player i've come across, the fascia sticks out a bit further, but this allows it to be tilted and for the disc to come out. hope that made sense
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I think its partly the wiring behind the unit that cause people grief, but you should be able to fit it without modyfying the heater box too much.
    Perhaps send a PM to hakhawk, as I believe he knows for certain.
    Devils_Thunder's Avatar
    Devils_Thunder is offline Riding high... Devils_Thunder Executive
    6.0L VZ SS Thunder
    Jan 2009
    Wodonga, NE Victoria
    I had a DVD player and a flip out screen in my VS. I had the screen in the standatd DIN slot and the DVD player in place of the pocket (slot with rubber mat in it). I had to cut the back of the pocket off and attatch the metal sleeve that came with the DVD player in its place.
    Everything fitted in fine and i had no troubles with space or wiring.
+ Reply to Thread
  1. HELP - Double Din in a VS Statesman
    By rolla83 in forum Car Audio
    Last Post: 25-12-2009, 06:02 AM
  2. Double Din
    By Kuka in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2009, 09:34 PM
  3. Double Din
    By Aussie_VZ in forum Car Audio
    Last Post: 13-01-2009, 09:18 AM
  4. VY Double Din HU
    By raZel in forum Car Audio
    Last Post: 09-10-2008, 08:09 PM
  5. double din with gps
    By slappa. in forum Car Audio
    Last Post: 18-06-2008, 10:14 AM
