You need to make sure you have a fat negative going to the engine, and a fat negative going to the body of the car. Seeing as this is in the car audio thread, I should mention that the cable between your negative battery terminal and the body should be the same, if not thicker than the power cables going to your amps.
LinkBack URL
About LinkBacks
