+ Reply to Thread
Results 1 to 4 of 4
Thread: What AMP for KICKER CVR 12" 2DVC (olderstyle)
    muffman001's Avatar
    muffman001 is offline Needs VL Distributor ! muffman001 Executive
    VL Berlina (NON Running) LOL ! NEED CAS !! PM ME !
    Mar 2005
    Whyalla ..
    Default What AMP for KICKER CVR 12" 2DVC (olderstyle)
    Hi all i got a older style kicker cvr 12" comp vr dual voice coil's @ 2 omh same as this
    RMS Output 200w Per coil (400w)
    http://www.suchartsound.co.th/images...ker_compvr.jpg
    my question is will a SONY XM-504Z 500w 4/3 channel power amp be good enough
    or will i be underpowering the sub i would be running it @ 4omhs
    also is there anyway to bridge the other channel ? or anyway i could run my pioneer ts-w300r off it too ? 150w rms singke 4 omh voice coil
    thanks
    Wrecking VL commodore ......
    Also have 4x 14" 5 spoke mags for sale or will swap for vl commodore working distributor + cas
    http://forums.justcommodores.com.au/...stributor.html
    holdenboy's Avatar
    holdenboy is offline Custom Car Stereo Systems holdenboy Calais
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    That Sony amp only produces 120wrms when bridged at 4 ohms. Definately not enough to drive the sub properly. It will work OK, but you risk overdriving the amp and sending the sub a clipped signal (not good for the sub).
    By the looks of it you wont be able to bridge the other two channels to power the second sub. Although there is another option......you could run the Kicker off two channels at 2 ohm (1 voice coil per channel) and then bridge the remaining two channels to run the Pioneer. But as i said before theres not enough power there to drive the sub properly.
    Personally i wouldnt bother running two different subs, but in the end its up to you.
    Theres plenty of other brands / models out there that will do the job better. Look at the Jaycar 4 x 100wrms model for example. 380wrms when bridged (both pairs of channels can be bridged) which is enough for your kicker.....then what i would do is get yourself a good pair of front splits and power them off the other two channels, 100wrms is plenty too.
    150db in a commodore =
    muffman001's Avatar
    Mar 2005
    Whyalla ..
    Default Thanks
    Thanks for your advice i will look into that amp tommorow when i go into jcar
    i should of posted the rest of my system before so ill do it now
    head unit is kenwood KRC-950 with 10 stacker
    4x JVC CS-HX645 2x in front door 2x in rear shelf
    1x pioneer GM-H44 running The JVC speakers
    should i just sell the pioneer sub and sony amp and buy a grunty amp to power this sub or should i keep the sony and use it elseware in the car ? like add another set of speakers or drive the JVC's with it and ditch the pioneer amp ? and spend a few $ on the side to get a more suted amp for the kicker
    Thanks again sorry if i confused you lol
    Paris Hilton
    Mar 2009
    Cairns White Rock
    If your after an alright amp, i recently picked up a Clarion APX1301 Monoblock from Ryda, for $170ish. They were on special and i think they still are. 400RMS @2ohm, good match for the kicker sub you have, and for the money, i think you'd be hard pressed finding much better.
    Ryda Car Audio - Clarion Car Audio APX1301 Car Amplifier($177.95)
+ Reply to Thread
  1. WTB 2006 Kicker 12" L7
    By SPLcamry in forum Swap / Wanted to Buy / Trade
    Last Post: 07-07-2009, 07:57 AM
  2. these Kicker 12" any good?
    By Summer-Sickness in forum Car Audio
    Last Post: 13-03-2008, 02:30 AM
  3. 2 12" kicker subs
    By badger__rox in forum Car Audio
    Last Post: 29-03-2007, 02:19 PM
  4. FS: 15" Kicker EX Sub.
    By MBS206 in forum Parts And Other Items For Sale
    Last Post: 22-09-2006, 03:09 PM
  5. Kicker Solo Baric 18" & Kicker Equalizer
    By sbkvp in forum Car Audio
    Last Post: 05-12-2004, 07:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
