Results 1 to 5 of 5
Thread: where to run the wires
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Default where to run the wires
    it's probably staring right in the face, but i can't find anywhere to run the wires through to the front doors. Are there some rubber gromets or something that can be removed? Thanks guy's
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Assuming VP's are the same as VS's, you should be able to pull out the trim under the steering column, and the trim peice with the vents leading to the door, then see a heap of wires going up the side, and eventually into the door.
    Man, thats a bad description...sorry, I'm tired and can't think straight
    EDIT: VP's don't have vents in the doors do they...so I dunno. Good luck with the hunt...
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    There should be for the VPs, youre car would have central locking i'd imagine? If so then you should see the rubber grommits in the door and pillar, and the tubing running in between?
    Edit: If youre meaning from the dash to the grommits, Philthy is on the money
    150db in a commodore =
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    (This has been along time since I have done this but if memory serves me correctly). You need to remove the air vents from both sides of the car. There should be a plug in the pillar for the loom that goes to the door. Unplug this and you can remove the entire grommet from the door and the pillar which will enable you to run new speaker wires through this grommet. Let me know if you need anymore info....
    cheers
    Simon
    Lets work as a TEAM and do it MY WAY!!
    Mar 2009
    Cairns White Rock
    thanks guy's, yeah i thought it may have been that bit of black rubber running between the door, but i wasnt sure what was inside (as i couldn't follow it back to anything) But yeah all good, and got it sorted, thanks everyone
  1. ecu wires
    By kniever in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2006, 10:40 PM
  2. What would these wires be for?
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2006, 11:00 PM
  3. What wires are these?
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2006, 10:51 AM
  4. Amp Wires?
    By todds_vt_2005 in forum Car Audio
    Last Post: 19-03-2006, 11:46 PM
  5. wires
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-11-2005, 09:10 PM
