Results 1 to 14 of 14
Thread: Vt Tweeter Wiring
    Vt Berlina 1998 Not my dp
    Jun 2009
    Frankston
    Default Vt Tweeter Wiring
    Was looking into my stock stereo today and noticed that my tweeters arnt hooked up. They are the stock ones so they have this plug on the end.
    searched my dash and couldn't find any plugs that they might plug into?
    did vt s1 Berlinas have the harness that compensates for these speakers? If so Where
    any help will be much apperciated
    Quote Originally Posted by Cobez View Post
    You sir, are as gay as aids and as camp as a row of tents. You also fail..
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yep, they S1 VT Berlina did have them connected, mine was. The plug will be nearby somewhere unless someone has cut it off.
    Jun 2009
    Frankston
    Angry
    Quote Originally Posted by StoneX View Post
    damn it myn must be cut off, might look again thanks
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    You can hook the wires from the tweeters in parallel to the wires going to the speakers in the doors.
    If you need anymore info just ask....
    cheers
    Simon
    Lets work as a TEAM and do it MY WAY!!
    Jun 2009
    Frankston
    will have a chop at it but replacing with new kit in a couple of months just wanted somfin to fill in the gap. but will have a go anyway
    LowVtWagon's Avatar
    LowVtWagon is offline LowVtWagon
    Holden VT Acclaim Wagon
    Dec 2008
    country
    Hey guys, sorry if this has been mentioned before but was wondering about installing tweeters!! where is the best place to put them??? i have heard people say front pillar and some say next to ur head!! i'm running a pioneer amp (2 channel i think) thats just running a 12" sub, clarion doubledin head unit and just original speakers. what do i connect the wires to?? amp or head unit or just connect to front speakers???? so many different answers!!
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    There are many good places to mount the tweeter, the easiest and most stealthy (so potential theives dont know youve got a decent system) is in the stock locations in each corner of the dash. Although places like the base of the A pillar and the kick panels are good spots too. If youre not fussed about stealth then i suggest temporarily mounting them in a few locations / angles and finding out which sounds best to you.
    I cant think of a worse place to mount tweeters than near your head, about 5 minutes of that will be painful.
    As far as what wires to connect them to, usually you will get tweeters with component (splits) speakers. You get a crossover which basically sends the high frequencies to the tweeter and the low/mid frequencies to the woofer. The crossosver has three spots for wires, one for the input from the head-unit or amp, one for the woofer and the other for the tweeter.
    150db in a commodore =
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Stock location for sure... Gives a good sound stage. Bright sounding tweeters might not be so good up there, but you won't know until ou try it. I had my first set up there and now I have them in the kick panels, next to my feet.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Another vote for stock location, although mine are temporarily down on the door pods and it still sounds good enough
    LowVtWagon's Avatar
    Dec 2008
    country
    still confused on the wire thing!!!! i know it should be a basic thing but i really want to get this right first go! sorry to be a pain! where should i run these wires??
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    So you have only a pair of tweeters? it "is" possible to wire them into the stock wiring but they will need some type of a crossover to cut the lower frequencies (they'll last about 3 seconds if you dont use some type of crossover or capacitor).
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by LowVtWagon View Post
    Connect the tweeter in parallel with the woofer in the door. You can splice the wires going to the woofer around the kickpanel area. Or you could run your new cable into the door and connect it up to the back of the woofer. It's up to you
    As above you'll need a crossover of some sort to prevent low frequencies from blowing up the tweeter. I think the stock wiring usually just has a capacitor wired in series with the tweeter but honestly i haven't looked (when installing aftermarket speakers i just unplugged my tweeters and left them in the dash).
    Either way, a ~13uf bipolar capacitor (anything from 10uf to 15uf should do) wired in series with the tweeter will do the trick. This will crossover the tweeter around 3khz which should be fine.
    edit - here you go:
    LowVtWagon's Avatar
    Dec 2008
    country
    once again guys sorry to be a pain!! the tweeters do have a crossover (says in the instructions) they are rockford fosgate RF-X1T. they reckon the power handling is 100 watts max. the only sub i run is boxed in the back so only standard speakers in the front and rear doors plus standard tweeters up in the dash (original equipment)! im guessing i could hook up the wires to the standard speaker?? would this be the same as hooking up the wires to the sub wires??
    Philthy's Avatar
    Aug 2005
    The woofer in that diagram is referring to the standard speaker, not a SUBwoofer, which is what you have in the boot.
    So yeah, you want them hooked up to the standard speaker wires, not the sub wire.
  1. Tweeter installation
    By pegg in forum Car Audio
    Last Post: 08-10-2008, 05:23 PM
  2. Tweeter question -3dB 0dB or +3dB????
    By Semtex in forum Car Audio
    Last Post: 18-11-2007, 09:13 AM
  3. Tweeter question
    By lasco in forum Car Audio
    Last Post: 05-03-2007, 08:49 PM
  4. VS Commodore Wiring/Tweeter Troubles.
    By [TUFFTR] in forum Car Audio
    Last Post: 31-12-2006, 09:05 PM
  5. VZ tweeter removal?
    By s7ormy in forum Car Audio
    Last Post: 26-11-2005, 11:58 PM
