Results 1 to 7 of 7
Thread: Easiest way to get power cable through VT firewall
    98VT_VIPER's Avatar
    98VT_VIPER is offline V6 makes driving more fun
    1998 VT 3.8 ACCLAIM
    Jul 2009
    CHCH - NZ
    Default Easiest way to get power cable through VT firewall
    heya just been looking to see how to get power cable through the fire wall of my 98 VT. all other posts say through the clutch but mines a auto so no clutch. and also i cant seem to get the dash off to get at the head unit any tips on that?
    Here we are, doing sixty miles an hour in top gear and the engine is doing 1,500rpm… It's idling! You fat Aussie slacker!
    James May on the Holden Monaro
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    People with autos use the clutch grommet. It's a black rubber solid grommet so pull it out, drill a hole in it, put it back and squeeze your wire through it.
    98VT_VIPER's Avatar
    1998 VT 3.8 ACCLAIM
    Jul 2009
    CHCH - NZ
    where abouts do i find it. cant see anything that looks like it could get a cable through
    98VT_VIPER's Avatar
    1998 VT 3.8 ACCLAIM
    Jul 2009
    CHCH - NZ
    and also i got the head unit out but only has the door speakers connected what colours are the 2 dash tweeters cables so i can find them and connect them up too
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    My car is an automatic as well, the hole is still their. Probably their for every car, makes sense to only manufature 1 type of chassis.
    Take the plastic above the pedals out, the big 40cm odd piece, pull the carpet down a little bit and you will see the hole. If you can't then get a mate to shine a light onto the firewall, then 'look into the light' . Its big enough for 0gauge wiring so its pretty obvious.
    Ronald Reagan (1986)
    holdenboy's Avatar
    VR Wagon
    Aug 2008
    Nelson Bay NSW
    You wont find the tweeter wiring in the stock stereo loom, they acutally "split" into two wires on either side of the dash, one goes to the door speaker and the other to the tweeters. If you connect your speaker outputs to the front speaker wires then the tweeters will work.
    150db in a commodore =
    VL Shaggin Waggin
    Jul 2009
    remove the plastic guard in the drivers side wheel arch..
    there's a grommet for the side indicator.
    you can run the cable through this grommet, and up near the side of the battery.
    simply replace the cover, and it holds the cable in place.
  1. power cable through firewall - VS stato
    By mazzstein in forum Car Audio
    Last Post: 29-12-2008, 04:31 PM
  2. Power cable through firewall VY
    By BO88YY in forum Car Audio
    Last Post: 30-09-2008, 06:08 PM
  3. amp power cable, No hole in firewall. :(
    By phat_com in forum Car Audio
    Last Post: 02-04-2007, 11:45 AM
  4. Running power cable in firewall "VP"
    By wrx884 in forum Car Audio
    Last Post: 07-01-2007, 11:16 AM
  5. Power Cable Through Firewall of VY
    By Exceler8r in forum Car Audio
    Last Post: 12-09-2006, 09:58 PM
